Old 11-12-2014, 04:07 PM   #1
joell
joell's Avatar
Drives: 2013 Hatchback
Question Help finding part number
Hello
The clear white plastic part that hold the rubber gromet of the hatch is loose,the water can leak inside the headliner.
I searched the catalog of parts but without luck, the part itself donīt have any marking that indicate a Toyota code XXXX-XXXX.
Silicone sealant and 3M tape cannot hold in place, Japanese Yaris 2013, sorry for the bad english
Thanks for any help
joell is offline   Reply With Quote
Old 11-13-2014, 11:09 PM   #2
bairjo
I usually find that the local Toyota dealer can give that info in 5 minutes. try that.
Old 11-14-2014, 06:33 AM   #3
That white part is considered part of the complete hatch wiring harness. You can't purchase it separately from Toyota.
Old 11-14-2014, 07:11 AM   #4
hondajt
hondajt's Avatar
Drives: 2013 Yaris LE 5Dr
You can make something out of hose sealer and silicon from Lowe's or Home Depot.
hondajt is offline   Reply With Quote
Old 11-14-2014, 08:32 AM   #5
The white plastic piece snaps into a large hole in the hatch opening and is designed to squeeze the molded lip on the black rubber boot to make a waterproof seal. When the hatch is open the black boot has a significant amount of tension on it as well.
You would have a difficult time making something to replace it and particularly finding a sealing compound that will stick to the painted metal and the rubber and form a completely waterproof seal (particularly for the O.P., who is in Panama, where it is hot and wet).
Old 11-14-2014, 08:36 AM   #6
hondajt
hondajt's Avatar
Yikes, yeah, I don't think I completely understood how it operated.....so in hindsight....the better idea is definitely to go buy the harness (and part) from the dealer or online.
Good luck.
Old 11-14-2014, 11:57 AM   #7
joell
joell's Avatar
Thanks for all the responses
I will evaluate all the options available:
1. Buy the whole harness
2. Search in the junkyard, some new yaris have crashed
3.Another post have a lead for possibles replacements, partial Part Name Code (82819-XXXXX) that will investigate more.
The best advice I can give is: Be careful when installing any reverse camera
Old 11-14-2014, 12:15 PM   #8
Eduardo_mty
Ctscott do you know the part number of hatch Wiring harness.
Joell i did the same "error" when i try to install reverse camera
Eduardo_mty is offline   Reply With Quote
Old 11-14-2014, 01:02 PM   #9
Any of these:
82184-52320
82184-52340
82184-52350
Old 11-14-2014, 05:41 PM   #10
Eduardo_mty
I found it, www.toyotapartsoverstock.com $82.41 usd
Old 11-15-2014, 02:18 AM   #11
ucsmfu
Drives: yaris le
what is the best way to remove that plastic part when removing the reverse camera ?
ucsmfu is offline   Reply With Quote
Old 11-15-2014, 06:34 AM   #12
Squeezing the tabs from below is the only way to remove it without deforming it.
Old 11-15-2014, 05:14 PM   #13
ucsmfu
Drives: yaris le
to access to the tabs below, will I need to remove the headliner ?
thanks
Old 11-15-2014, 08:29 PM   #14
thanks
Partially, or get your hand up between it and the roof.
Old 12-21-2014, 11:06 AM   #15
joell
joell's Avatar
Update: I take the broken part to a 3D printing shop, they scanned and printed in black ABS, cost $30 dollars.
Old 12-21-2014, 11:50 AM   #16
Eduardo_mty
Do you have a finished printing part.
Where are you located ?
Old 12-21-2014, 11:50 AM   #17
Eduardo_mty
Picture from finished part printing
Old 12-21-2014, 06:33 PM   #18
joell
joell's Avatar
This is the finished printed part, i dont have the computer archive of the 3D model.But you can search locally for some place that can help you: http://www.3dhubs.com/3dprint
Top glove box part number? Nips Cosmetic Modifications (Exterior/Interior) 6 02-24-2012 11:39 AM
Yet another cabin air filter part number... Goose DIY / Maintenance / Service 0 05-05-2010 05:15 PM
Part Number?? nick1983 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 04-12-2007 01:43 PM
A quick favor... I need a part number ChinoCharles General Yaris / Vitz Discussion 5 04-10-2007 08:36 PM
HELP: JDM Armrest Console Box part number GabL Cosmetic Modifications (Exterior/Interior) 7 10-24-2006 11:12 PM
