Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
Tachometer Illumination
So, I've searched and found a few threads regarding aftermarket tachometer illumination. I've wired up my Autometer Autogage tach, and now need to illuminate it.
I saw that you can use an add-a-fuse in slot #23 as shown here (I have the mini add-a-fuse, but it's only rated to 10 amps): http://www.yarisworld.com/forums/sho...r+illumination ... and I've heard of people tapping into the stereo dimmer wire. Can anyone give me a definite answer as to how to illuminate this tach? Is one way better than another?
Subcompact Culture: The Small car blog |
#2 | |
Start another Oil Thread!
hopefully one bulb won't pull more than 10 amps :D i say add-a-fuse
you nailed it sir.
The output of the light control rheostat (connector D29) controls the radio illumination, AT shift lever illumination, and AC control illumination.
You can tap into the green wire in pin 2 for the negative side of the illumination circuit and any +12V source as your positive (such as the light blue wire in Pin 10). Pin 2 varies from 0 Volts (full brightness) to 12 Volts (fully dimmed). This will allow the tach to dim with the rest of the controls. |
So, I did the add-a-fuse thing using fuse #9 and the tach illuminates ... but it stays on even if the car isn't on ... Can I just use any other 10am fuse spot? Can I use any open port with the add-a-fuse?
I put the add-a-fuse in slot #7 and it all works fine. Woo hoo. Now let's hope my wiring job holds up.
| Tach Illumination wire | Liu997 | DIY / Maintenance / Service | 6 | 05-29-2009 12:11 PM |
| Source code for Yaris Tachometer | metalshark | DIY / Maintenance / Service | 27 | 04-06-2009 01:41 AM |
| LED Tachometer Units | Sodium Duck | Performance Modifications | 5 | 02-28-2009 09:06 AM |
| FS - Brand New "TRD Styled" Tachometer (Red on Black) | Ran Kizama | Items for Sale by private party | 9 | 05-09-2007 04:30 PM |
| HELP tachometer problems!!! | SamDaYarisMan | In Car Entertainment + Electronics (audio / video / alarm) | 16 | 09-08-2006 03:26 AM |
