Old 05-03-2009, 07:19 PM   #1
Liu997
Drives: 2008 Red Yaris LB
Tach Illumination wire
Where can I hook up my white illumination wire. I heard its not good to hook it up to the dimmer wire.
Liu997 is offline   Reply With Quote
Old 05-03-2009, 08:53 PM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
If you don't mind it not dimming you can hook it up to the parking lights so that it's only on when your lights are. Pin 29 - green wire.
Old 05-03-2009, 09:06 PM   #3
Liu997
yea ill try that
Old 05-03-2009, 10:14 PM   #4
Liu997
hmm.. doesn't seem to work
Old 05-03-2009, 11:27 PM   #5
Liu997
Also, what is a good subsitution for the power wire cause I don't trust running a wire from the fuse box.
Old 05-04-2009, 01:14 AM   #6
Altitude
Altitude's Avatar
The blue colored square in the junction diagram is where I pulled the switched 12v.
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 08:53 PM
Dimmer Wire for Tach mrrock DIY / Maintenance / Service 7 11-29-2006 07:18 PM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
