Old 06-12-2009, 07:12 PM   #1
kngrsll
Apexing Egg!!
kngrsll's Avatar
Hyperco 5.5" single pigtail rear spring test
Alright, i got one of the two sets of springs i ordered today. This pair of springs is the 275 lb rated, 5.5" diameter, 12" free length, single pigtail rear spring. When i first got them, i thought, damn these things are big!! Then i thought, shit, they don't compress at ALL!! Only one of these would actually become an issue. Feel free to speculate :)
Ok, so in review, i measured the rear spring on the car (Tanabe DF210) to be about 12" free length and 5.5" in diameter with a spring rate of 123 lbs. I thought with the rubber on each end of the spring out, they may just fit. I ordered both rates bc i thought that the 175 lb would have a much better chance of fitting, but i don't know this as they are not here!
So first i measured the height of the rear wheel well stock:
looks to me to be about 24.5" roughly...
So then i jacked the car up and pulled out the rear springs. Before putting in the new ones, i took a picture of them in comparison.
So, as you can see, they are nearly the exact same free length. Which is good that i guessed it right, but bad that it wasn't good for the rear height when it was installed! Also, the diameter of the Tanabe spring is probably closer to 5" rather than 5.5", and in fact, i think they sell a 5" spring just like these, so that may be a better option.
I went ahead and installed them, they just slid in and i lowered the car. The rear of the car was pretty high. I didn't go drive around on them, but i put the shocks in, and the droop length kept the springs in fine. So here are two pics, one of the height and one of the measurement of the height.
I see that as 27 1/4", so nearly 3" higher. Now, one could just trim 3" off the spring, but then i think you will have issues of losing the spring if you were to lift a rear wheel. That no good. What you could do is use the rubber hats and leave it in for another inch or so and they mostly compress. Another idea was to weld in a short metal tube that is about 2.5 or 3" in diameter on the spring seat to keep the spring in place if it were to come off the lower seat (and that would be REALLY bad. Another option would be to reduce the droop length, which is possible with some simple straps.
Anyways, thought i would share. Hope it helps, I will try the 175 lb springs when i get them. If Loren or largeorangefont wants to do some math, feel free! :D I think the lighter springs will fit perfect, but we will see.
Oh, i got another nice package today too!
15x7 +25mm 13 lb Team Dynamic Spec Miata wheels!! :D so much win!!
HA!! IT WORKED!!! I cant believe it!!
Ok, so i took the springs to a random muffler shop, i approached one of the workers outside with my springs and asked if they could do a cut on them. He said no problem, got his torch out, and cut where i measured! So that was way easy, i thought it would be alot harder to get someone to do that lol.
Ok, so i didnt get pics of that stuff, i should have. I measured from the very bottom of the spring when it was sitting level, and i rotated the spring until the bottom part of the coil got to 2.5". So i made a line there and had it cut. The free length of the spring now was 9.5".
I went home and jacked the car up. I didnt have to unbolt anything now lol, i just used a wrenched and popped the springs out! So once they were out,i installed the rubber hat on top, and i put the new ones in, and lowered the car. This was tricky, you lower it a little and make sure its in place, and then go all the way. Well here are the pics:
Before
After
Can you tell a difference? I can't!! and if you dont believe me, look behind the car, black springs in the first pic, red springs in the second!
So then the problem of the springs staying in came up. So i drove the car around, and i had no problems. I drove about 30 miles. I went to an empty parking lot and did donuts, and slides, and anything to try to make something bad happen and nothing did. The problem will really come with large pot holes or something like that so that may have just been for fun! :) So i visited a few places and such, and couldnt really think of how to do the strap thing yet. I figured, why not use the spring as the strap? So my temporary solution is these hardcore zipties. they are metal and are made to support 100 lbs of weight themselves. There are 6 on there, so that splits the load up pretty good. Anyone know the weight of the rear subframe? They came from Advance Auto in the Performance Parts section.
So how did i do that? Well there is a hole in the top spring perch, you can slide the tie wrap in it, over the spring, and tighten it. For the bottom, there are holes all over in the perch. So do the same, around the spring and tighten to the perch. There are two on the bottom and one on the top.
Next, to test this, i jacked up each side individually. The spring stayed in place, the zip ties held it in!
So this is the amount the car is off the ground right before the tire comes up (and the spring and straps carry that corner load.)
This is a terrible pic, but you can see the straps (untrimmed!)
The same picture with the spring loaded instead.
See? Its normally really hard to get the rear tire off the ground!!
I even stood on the wheel and jumped up and down on it to test the straps, they work!! im only 165 lbs but, it passed my test. I think i will make straps later, but now i can really do them right and not in a hurry.
So how does the car drive?? FANTASTIC!! Loren is so right about this chassis, it really wants more rear spring!! so now it has 175 lb springs in the front and 275 lb springs in the rear. The car is so much more agile. I had to really bump the shock settings up to make up the difference, so i am glad i had that adjustability. For anyone with blues, i would suggest upgrading the rears to either the blue xD shock or just get the HTSs. You may be able to just do the rear HTS and keep the blues up front if money is an issue, but the front adjustability is nice. I have not played with shock settings much yet, i think i will only play with the rears once i get the settings i like.
So I have an autox tomorrow, lets see how this set up works!!
A big thanks to everyone who helped and had some input/ideas for this!! You know who you are!! (and if you guys dont: Loren, Tamago, and largeorangefont)
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 06-12-2009, 07:58 PM   #2
so if you were doing an offroad Yaris, those would be great...
I wish you had a pic of the whole car with the rear jacked up like that...
Old 06-12-2009, 08:09 PM   #3
kngrsll
Apexing Egg!!
kngrsll's Avatar
the front looked the exact same as before, it didnt go up at all... it wasnt higher at all. so it looked like a wedge LOL
Old 06-12-2009, 09:46 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
good thread, good to know about the springs, and MMMMMMMMMMMMMMMM at those wheels! can't wait to see your +15mm rear fitment! did you install your hub spacers already?
Old 06-12-2009, 09:58 PM   #5
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Simple math here. One rear corner = 2300 x .5 x 40% or about 460 pounds.
Your 123# spring is compressing approximately 460/123 or 3.75" to an installed length of about 8.25". (this is disregarding motion ratio just for simplicity)
Your 275# spring is only compressing 460/275 or about 1.75" to an installed length of 10.25"... a full 2" taller than stock.
Your actual results were about 3/4" more than that, but looking at the side-by-side photo, the old springs were maybe half an inch shorter than the new ones. That's part of it. The rest probably comes down to not considering the motion ratio, etc.
My point is that if you'd done a little math, you should have EXPECTED your new 275# spring to raise the car by at least 2" without question. Can you get 10" springs or 9" springs?
Very cool that "standard" race springs fit so well. How 'bout some photos of how they fit in the perches? This is neat stuff!
Old 06-12-2009, 10:37 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
3/4 makes sense as gordon told me the typical motion ratio is around 70% ;)
Old 06-12-2009, 11:32 PM   #7
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Cut the springs, buy some limiting straps, install them and enjoy.
Old 06-13-2009, 07:50 AM   #8
kngrsll
Apexing Egg!!
kngrsll's Avatar
I got them yesterday as well, i was going to save them for another thread. I have not put them in yet though!
yea, i agree, i should have done that. Either way, the shortest they make is 11", so it may not have been adequate enough.
I think this is exactly what i am going to do!
then i will get pics of them in the bottom perch. They fit so good!
Old 06-13-2009, 08:46 AM   #9
kngrsll
Apexing Egg!!
kngrsll's Avatar
Oh, any suggestions for a droop strap?
Old 06-13-2009, 10:29 AM   #10
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
i want to see pics of the car now! with the rims =)
Its a Chao!!!
Old 06-13-2009, 01:52 PM   #11
kngrsll
Apexing Egg!!
kngrsll's Avatar
SUCCESS!!
Before
After
So how does the car drive?? FANTASTIC!! Loren is so right about this chassis, it really wants more rear spring!! so now it has 175 lb springs in the front and 275 lb springs in the rear. The car is so much more agile. I had to really bump the shock settings up to make up the difference, so i am glad i had that adjustability. For anyone with blues, i would suggest upgrading the rears to either the blue xD shock or the HTS. You may be able to just do the rears and keep the blues up front if money is an issue. I have not played with shock settings much yet, honestly i think i will only play with the rears once i get the settings i like.
Old 06-13-2009, 02:09 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
looks really good! i'll be following shortly behind you when my stuff arrives at the end of the month
Old 06-13-2009, 02:14 PM   #13
kngrsll
Apexing Egg!!
kngrsll's Avatar
Joel, check your gmail.
I can't wait to see you follow it up, i'm sure you will find some refining to do!
Old 06-13-2009, 05:56 PM   #14
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Great thread...
You Sir, have my respect...
Good to see more people experimenting...
Old 06-13-2009, 06:25 PM   #15
kngrsll
Apexing Egg!!
kngrsll's Avatar
Originally Posted by CASTREX View Post
Great thread...
Thanks!!
Old 06-13-2009, 06:54 PM   #16
Loren
What?
Loren's Avatar
Now, the question is... what spring rate did you end up with?
We can do some math and get close. Give me the diameter of the wire, the number of active coils "before" and the number of active coils "after" and I'll crunch it for you.
This is awesome stuff. After today's autocross, I think a tad more rear rate (even more than the 400# I already have) would be good. Will make it kinda clunky on the street, which it already is. But, I'm still having to jack the rear shock adjustment to almost full stiff to get the front to hook up like I want it to. Need more rear rate!
Old 06-13-2009, 07:07 PM   #17
kngrsll
Apexing Egg!!
kngrsll's Avatar
what rates are you running up front again?
Old 06-13-2009, 07:03 PM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
penguin garage is currently planning adaptors to allow yaris users to use standard 2.5" race coils. stay tuned! and your clunking noises will be gone, thanks to urethane.
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
Track Suspension id3379 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 85 06-11-2009 05:59 PM
Rear spring swap info The Spectacle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-22-2009 09:37 PM
ideal spring rates for coil-overs on Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 30 01-27-2009 04:24 PM
