#1 |
![]() ![]() Drives: white and red shiny things Join Date: Jan 2009
lowering spring specs for Yaris
Since I originally posted asking about different lowering spring rates for the Yaris NCP91 chassis code, I started searching around until I realized I have a Hyper Rev magazine for the Yaris (duh!)
So I copied the rates and drops and am putting them here. MODS I hope you make this a sticky because this would be most helpful for everyone! Progress Group Springs – 110 lbs/in front and 130lbs/in rear 2kg/m front and 2.3kg/m rear DROP: 1.7’ F and 1.8’ R Tanabe NF210 – 140 lbs/in front and 123.2 lbs / in rear 2.5kg/m front and 2.2 kg/m rear DROP: 1.1’ F and 1.3’ R Tanabe DF210 - 168 lbs/in front and 123.2 lbs/in rear 3.0kg/m front and 2.2 kg/m rear DROP: 1.6’ F and 1.8’ R Tanabe GF210 - 218 lbs/in front and 196 lbs/in rear 3.9 kg/m front and 3.5 kg/m rear DROP: 1.2’ F and 1.4’ R TEIN H-Tech 157 lbs/in front and 179.2 lbs/in rear 2.8kg/m front and 3.2 kg/m rear DROP: 1.4’ F and 1.0’ R TEIN S-Tech 168lbs/in front and 196lbs/in rear 3.0kg/m front and 3.5 kg/m rear DROP: 1.4’ F and 1.2’ R (closer to 2' F&R accdg to users) Espelir Active Super Down 140lbs/in front and 168lbs/in rear 2.5kg/m front and 3.0/kg/m rear DROP: 1.4’ F&R C-One Motorsports 212.8lbs/in front and 145.6lbs/in rear 3.8kg/m front and 2.6kg/m rear DROP: 1.0’ F&R BLITZ 140lbs/in front and 168lbs/in rear 2.5kg/m front and 3.0 kg/m rear DROP: 1.4’ F&R RS*R 180lbs/in front and 171lbs/in rear 3.23 kg/m front and 3.06kg/m rear DROP: 1.2’ F&R (titanium springs available, same spring rates and drop) Megan Racing No published spring rates DROP: 1.5' F&R H&R No published spring rates DROP: 1.2' F & 1' R Eibach No published spring rates DROP: 1.1' F & 0.9 R * The specs for the Tanabe NF210, DF210 and Progress Springs I took from the Microimage website. The rest I took from my Hyper Rev magazine. ** I used 56 to convert kg/m to lbs/in vis-a-vis. *** Hyper Rev lists a range of the actual DROP so I simply put in the lowest drop but the variance is only 5mm from highest possible to lowest possible drop of the springs. **** All spring rates and drops in inches are rounded off to the nearest 100th decimal for simplicity's sake. At most you're looking at 0.02 variance. ***** If there are any errors please do post up and tell me so we can correct it. Thanks! If anyone wants the drops and spring rates for popular lowering springs for the older Yaris / Vios platforms and chassis, PM me your chassis code and I will post it here as well. Right now these are for all NCP91 chassis Yaris.
08' Yaris HB 5dr: RAYS 57 Motorsports 17X7 / K&N SRI / TANABE axleback exhaust / ULTRA RACING complete braces / MEGAN RACING complete braces / NEX coilovers / NEX 330mm 4-pot front BBK / PENGUIN GARAGE hub spacers / HOTBITS headers / BUDDY CLUB oil cap and rad cap / APP SS brake lines / HKS synthetic lubes / RECARO SR5 seats / TRD shiftknob / cheap FEDERAL (free) tires lol. NEXT: HKS F-CON iS Last edited by botchilah; 05-17-2009 at 10:30 PM. |
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
aren't tein s tech's closer to 2". i know for a fact im not rolling on an 1.5" drop.....
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
#3 |
^ Yes, I've heard that too, more like a 2" drop.
I don't think there is a GF210 for us. H & R is another spring, but they don't publish a rate. And the new springs from China that I have, 1.75" drop (more or less) and 4k front, 3.1k rear.
#4 |
![]() ![]() ![]() Drives: Flint Mica Sedan Join Date: Oct 2008
Good stuff, this should def be a sticky after some editing and more springs/rates.
#5 | |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
Awesome info though, and a complete list should help with the amount of "which springs should I get" threads. |
#6 |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
I thought the AOE Tigertecs were about 1.5" or that's what I remember from the test information you were telling me about? I guess either way I'll find out soon just how low is low! lol
#7 |
yeah, that's why I said "more or less"? I only have a picture to go by until my TEST SUBJECT comes through. :: coughs politely ::
#8 | |
As I've said, if there are any mistakes, let me know so we can edit it :) I'll go check on those Megan springs right now. RE GF210, there's an application listed in Hyper Rev for the NCP91. Might be a JDM only product? I can double-check with my local Tanabe supplier though.
08' Yaris HB 5dr: RAYS 57 Motorsports 17X7 / K&N SRI / TANABE axleback exhaust / ULTRA RACING complete braces / MEGAN RACING complete braces / NEX coilovers / NEX 330mm 4-pot front BBK / PENGUIN GARAGE hub spacers / HOTBITS headers / BUDDY CLUB oil cap and rad cap / APP SS brake lines / HKS synthetic lubes / RECARO SR5 seats / TRD shiftknob / cheap FEDERAL (free) tires lol. NEXT: HKS F-CON iS |
#9 |
Yea, I think I read s.techs are 1.8 or 1.9 drop
#10 |
Scrubble with a poke.
Drives: 2009 Yaris LB Join Date: Jul 2009
Is there another to show us what shocks and struts will net the best or most agressive combo yet?
"If you cannot find truth right where you are, where else do you expect to find it?" Dogen |
#11 | |
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
#12 | |
TRD Sportivo Bilstein Premium Order Line KYB SR Special KYB Lowfer Sports el-Sport Type Standard el-Sport Type Adjustable el-Sport Type Adjustable2
#13 |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
TRD Red. 1.2" lower front and rear according to manf.
Real world... shortly after settle-in and still after 40,000 kilometers, closer to a 2" drop in my '08 sedan when compared to the same model with stock suspension which parks beside me daily at the office. His looks like an off-road set-up in comparison. Yuck!
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
#14 |
![]() Drives: Yaris Sedan 2008 Join Date: Oct 2008
I am having a same issue. I want to change other brand. Anyone have idea?
#15 |
If anyone has a set of springs or rear sway bar for sale let me know. I am trying to stabilize the car in turns and dont have a lot of cash.
#16 |
the GF210 is made by Tanabe, but not sold in the USA.
You can add TigerTec springs to the list: 4k front/ 3k rear 1.7" drop
#17 |
cool, well I am looking to spend 25-50% of retail... pm me and let me know what you have to offer price wise.
#18 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
Anybody ever find out what the spring rates are for the Megan Racing lowering springs?
| what to look out for when installing lowering springs | songa | Performance Modifications | 34 | 09-15-2012 03:29 AM |
| What alignment do you need after lowering spring and shock/strut install? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 05-07-2009 12:23 PM |
| lowering spring life..?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 04-14-2007 01:31 AM |
| FS: Lowering Spring by Spirit (Hatchback) | nevermorez | Items for Sale by private party | 6 | 02-18-2007 12:32 AM |
| Where can i buy a lowering kit and spring 4 toyota yaris S sedan (4 doors) | mariosuper | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 07-07-2006 09:06 PM |
