Old 06-28-2009, 10:03 AM   #1
XYaris
Drives: '09 Yaris LB
No RPM signal? Any ideas?
I installed a tach a few months ago with the provided wire clips. When I lost the rpm signal I figured it was because of a bad connection. However now I've made a new connection and the tach is not reading any rpm. All fuses are good and the tach is powering on. Is it possible or likely that it's a connection inside the guage itself? It's one of those 30 dollar sunpro things after all. Anyone in the NYC area have a scangauge?
If this damn car came with a tachometer in the first place, all this hassle could be avoided.
I appreciate any thoughts...
XYaris is offline   Reply With Quote
Old 06-28-2009, 10:24 AM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
sounds like a bad tach.
Originally Posted by xnamerxx
you nailed it sir.
Old 06-28-2009, 10:31 AM   #3
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
I'd agree with Tamago, I think the tach may have crapped out. I have the same tach and it's already starting to deteriorate (moisture is creeping in behind the face).
Make sure to check your power/ground connection too.
Old 06-28-2009, 03:55 PM   #4
+1
Old 06-28-2009, 04:14 PM   #5
XYaris
Problem solved...for now. I walked around the corner and bought another tach. Same brand different size. In six months when this breaks I will buy something decent. I just HAVE to have a tach. On this car with such a silent stock engine and exhaust its so hard to tell what the engine is doing without some visual indication. Did I mention I think it's lame that toyota didn't spec one?
Thanks a lot guys.
Old 06-28-2009, 04:47 PM   #6
RedRide
RedRide's Avatar
Thanks a lot guys.
I agree. I can't live without a tach either and the quiet enging and exhaust just add to the problem as you said.
Anyway, this is why I recently ordered a SpeedHut "revolution" tach for my new (manual tranny) Yaris.
NAV SYSTEM ANTENA SIGNAL BLOCKED BY TINT ON WINDSHIELD Giobatera In Car Entertainment + Electronics (audio / video / alarm) 15 07-08-2009 11:55 AM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 01:41 AM
Optimal RPM for shifting Gears ? JapRulezz Performance Modifications 8 03-07-2009 05:16 AM
RPM Gauge Install rwseattle DIY / Maintenance / Service 1 04-15-2007 01:23 PM
Turn signal audible alert paultyler_82 Performance Modifications 7 10-01-2006 11:21 AM
