Old 03-05-2009, 08:39 PM   #1
JapRulezz
JapRulezz's Avatar
Drives: yaris sedan 2NZ-FE
Exclamation Optimal RPM for shifting Gears ?
How can i get the most acceleration out my car during shifting gears
should i just push the rpm to the redline or what?
i am asking because whenever i read some cars specs i find (4 example )maximum Hp @ 3600 RPM or maximum torque @ 5500 RPM
and which translates acceleration more torque or hp ?
JapRulezz is offline   Reply With Quote
Old 03-05-2009, 09:03 PM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
you will get the feel of where the powerband lies as you get used to driving the car more.
Old 03-05-2009, 09:11 PM   #3
turboyaris
Drives: 2007 Yaris Sedan
Send a message via AIM to turboyaris
http://www.vettenet.org/torquehp.html
http://www.bgsoflex.com/shifter.html
turboyaris is offline   Reply With Quote
Old 03-05-2009, 11:04 PM   #4
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Maximum acceleration will always come from revving as far as the engine will rev without hitting the rev limiter. The torque TO THE WHEELS will always be lower after you shift to the next higher gear than it is at the top of the lower gear, even though torque and horsepower decrease significantly at the top end.
The common misconception is that shifting earlier puts you at the torque peak after the shift into the next gear, which is great... but you'd still be putting MORE torque to the wheels if you'd stayed in the lower gear longer! Do the math if you need to prove it to yourself, but that's the way it is.
Old 03-06-2009, 10:37 AM   #5
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Some first hand experience...
I did some testing on my car with a G-tech device (measures acceleration)
And I always achieved better times on the 1/4 mile by shifting at 6,400rpm (red line) in comparison to shifting at 5,900-6,000 rpm
Old 03-06-2009, 10:48 AM   #6
JapRulezz
JapRulezz's Avatar
i know about feeling ...... i want pure science and numbers !!
Old 03-06-2009, 11:22 AM   #7
long straight road/drag strip, friend with a stopwatch, go over and over, each time at different shift points, you'll see the results right there
Old 03-06-2009, 11:38 AM   #8
Loren
What?
Loren's Avatar
Engine HP x Gear Ratio x Final Drive Ratio x Factor for tire diameter = Effective HP
Fill in the blanks and do some math.
Old 03-07-2009, 04:16 AM   #9
Ferret_san
Hack.... What hack ??
Ferret_san's Avatar
Drives: 07 YR
1st ... 1-onethousand...2-onethousand...3-onethousand...4-onethousand...5-onethousand...6-onethousand...<change!>...<redline>
2nd ... 1-onethousand...2-onethousand...3-onethousand...4-onethousand...5-onethousand...6-onethousand...<change!>...<redline>
3rd ... 1-onethousand...2-onethousand...3-onethousand...4-onethousand...5-onethousand...6-onethousand...<change!>...<redline>
4th ... 1-onethousand...2-onethousand...3-onethousand...4-onethousand...5-onethousand...6-onethousand...<change!>...<redline>
5th ... is for pussies.
Last edited by Ferret_san; 03-07-2009 at 04:17 AM. Reason: That's RPM not seconds you skirts !
Ferret_san is offline   Reply With Quote
MUST READ!!! MPH to RPM to Time ratios,gas savings! eco Off-topic / Other Cars / Everything else Discussions 13 09-30-2007 02:00 PM
RPM problem. rwseattle Performance Modifications 7 04-03-2007 11:09 AM
Shifting RPM GabL DIY / Maintenance / Service 10 08-06-2006 05:40 AM
