Old 07-24-2009, 12:47 PM   #1
regal
Drives: 09 Yaris 3 Dr White LB
Tall thin Snow tires for 14" rims
I have 14" steelies from my civic and I like to put snow tires on them on the cheap. I heard 14" was better for snow than 15" and that has been my experience in the past. What size tire should I get, I need tall and thin as I am lowered on TRD springs. Expensive snow tires aren't in the budget.
Anyone know where to find odd balls like:
155-75-14 or 165/75-14 cheap before the fall season drives prices up?
If not what is a good compromise size?
regal is offline   Reply With Quote
Old 07-24-2009, 12:52 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
did you try www.tirerack.com and see what they recommend for the yaris?
the diameter of the wheel has nothing to do with the snow-worthiness.
Originally Posted by xnamerxx
you nailed it sir.
Old 07-24-2009, 01:27 PM   #3
regal
I've always had better luck with small skinny tires in the snow. My jetta had 13" rims and would drive by SUVs in the ditch. I'm coming up with nothing on the tire-rack
Old 07-24-2009, 01:29 PM   #4
Tamago
Tamago's Avatar
Drives: ZZW30
again, diameter of the wheel has nothing to do with a tire's snow worthiness.
you nailed it sir.
Old 07-24-2009, 01:30 PM   #5
Tamago
Tamago's Avatar
Drives: ZZW30
something tells me you didn't even try on tirerack.
http://www.tirerack.com/tires/Compar...nce=W&x=11&y=7
you nailed it sir.
Old 07-24-2009, 01:34 PM   #6
regal
I saw those, Those are all 23" tires, with TRD drop they would look rediculous?
I need to be close to 24"s
Old 07-24-2009, 01:35 PM   #7
Tamago
Tamago's Avatar
Drives: ZZW30
no you don't.
dude, you're worried about LOOKS ON A WINTER TIRE SETUP...
you nailed it sir.
Old 07-24-2009, 01:39 PM   #8
regal
165/75/14 would not only fill the wheel well better but it would do better in the snow, the thinner the tire the better on hills in Pennsylvania.
I saw some for sale a few weeks ago but can't find them now.
Old 07-24-2009, 01:53 PM   #9
regal
Here we go 23.6" diameter.
Michelin X Ice 175/70/14 $47.
Its ashame the 165 size has been abandoned, I guarantee you that a skinny rim climbs snow covered hills better.
Thanks for the discussion. I agree that tire diameter doesn't affect snow performance, but typically a smaller diameter wheel will take a skinnier tire. See where I am coming from now?
Old 07-24-2009, 03:58 PM   #10
MUSKOKA800
MUSKOKA800's Avatar
Yes, narrow (skinny) tires perform best in snow (See World Rally Cars). That said, Tamago is correct. Rim diameter isn't a factor.
I have snows on 14's for my sedan. They're too short when combined 175/65/14 snows and the TRD drop. Much problems last winter getting through my commutes.
I'm looking for taller rubber for the 14's or a 15" set-up for next winter.
Old 07-24-2009, 04:32 PM   #11
regal
The Michelin X Ice 175/70/14 have a diameter that is greater than many 15" setups. I ordered a set.
Old 07-24-2009, 04:33 PM   #12
regal
[QUOTE=MUSKOKA800;358211]. Rim diameter isn't a factor.
QUOTE]
It is a factor in that you can get a less wide wheel in a smaller diameter generally easier.
Old 07-24-2009, 05:32 PM   #13
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
GOOD LUCK with the yaris and its snowplow front end in the winter. that drop plus the smaller tires should equal a nice snow packed engine compartment......
Old 07-24-2009, 06:09 PM   #14
regal
The tires are actually bigger than my 15"s because they're 175
Old 07-24-2009, 08:03 PM   #15
run 175-65-14 and 185-60-14 on the yaris and aveo in winter....never had any problems
Old 07-24-2009, 10:26 PM   #16
SailDesign
Drives: .
Hmmm... Still smaller diameter than the 185/60-15 that comes stock on most new Yarii. Not by much, though.
185/60-15 = 23.74"
175/70-14 = 23.65"
Old 07-25-2009, 12:50 AM   #17
thepoche
thepoche's Avatar
Drives: Toyota Yaris CE
Hankook make the i*pike_w409 in 165/65R14. That's what I wanted to buy but they nobody had them in stock in my area. If you order some now, you probably can get them before the winter
thepoche is offline   Reply With Quote
Old 07-25-2009, 01:24 AM   #18
regal
22.5" diamter?, you need at least 75 in a 165
Can I use stock tires on these 15" rims? songa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 02-18-2009 08:11 AM
stock steel rims for 15" snow tires uspnpc Willing to Buy by private party 5 01-02-2009 12:23 AM
FS: OEM 15" Scion Rims & Tires....Brand New crabbadam Canada 5 11-27-2008 07:14 PM
Need help when ordering my tires and rims thomasward00 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-26-2007 10:40 PM
FS: 07 yaris RS stock rims n tires thegame11 Items for Sale by private party 5 04-15-2007 02:25 PM
