Old 08-11-2009, 03:41 PM   #1
dani1983
Drives: 2007 YARIS
strange noise before the car stops
hello,
I hear strange noise that came from the front right wheel, the noise appear when I reduce the speed to under 20 KPH and until the car stops (i not touch brakes) only after i drive around 100km.
The noise is very similar to the noise of worn out brakes (but i not touch them).
what it could be?
dani1983 is offline   Reply With Quote
Old 08-11-2009, 03:53 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Worn out disk brake pads are supposed to make a squeaking or scraping noise when you're not using them. The noise goes away when you step on the brakes. When you get a scraping noise when you use the brakes, they're past worn out. The disks are ruined by metal scraping on metal.
Old 08-12-2009, 03:11 AM   #3
dani1983
Drives: 2007 YARIS
Why worn out disks supposed to make a squeaking or scraping noise when I not using them, and only in a low speed after I drive around 100km?
(I change them before 21000km)
Old 08-12-2009, 09:55 AM   #4
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
A rock behind your brake caliper.
Old 08-12-2009, 12:02 PM   #5
dani1983
Drives: 2007 YARIS
what you mean?
what is the solution for this problem?
Old 08-12-2009, 01:03 PM   #6
1stToyota
1stToyota's Avatar
Originally Posted by dani1983 View Post
what you mean?
Look at the condition of your rotors & look for evidence of metal dusting your wheels.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 08-13-2009, 12:00 AM   #7
Yaris Hilton
Smile
Disk brake pads have little metal things molded into them that rub the disk when the pads wear down to them. That's what makes the noise that tells you your brakes are worn out. The noise is only heard at low speeds when your foot is off the brake and goes away when you step on the brakes. That's the way disk brake pads have been made since the early 1970s or so. Like I said, if you get a grating noise when you step on the brakes, they're PAST worn out! If you are prone to zipping up to stops and standing on the brakes, you can wear them out surprisingly quickly. (Plus you waste lots of gas that way.)
Old 08-13-2009, 03:51 AM   #8
dani1983
Drives: 2007 YARIS
So the solution is to change the brake pads?
Old 08-13-2009, 11:56 AM   #9
Yaris Hilton
Smile
Maybe. I'd first inspect them. Sounds like worn pads from here, though.
Old 08-13-2009, 12:37 PM   #10
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
i had the same thing on my XB, when i pulled the wheel off i noticed the heat sheild was dented in a bit where a rock must of hit it just right. I had to pop it back a bit and the sound was gone. simple as that
http://www.4055design.com
Old 08-13-2009, 01:13 PM   #11
Yaris Hilton
Smile
Yep, could be something like that. Need to take a look at the brakes, or have someone who knows what they're doing do so.
Old 08-14-2009, 11:06 PM   #12
kustom play
Drives: 07 liftback
could of been a number of things listed, im going to take a guess and say dust or grime
did you figure out what it was?
Old 08-15-2009, 07:42 AM   #13
dani1983
Drives: 2007 YARIS
Can you precise where I should check the dust or grime.
Old 08-15-2009, 09:22 AM   #14
Yaris Hilton
Smile
http://lmgtfy.com/?q=disk+brake+inspection
Old 08-15-2009, 12:56 PM   #15
dani1983
Drives: 2007 YARIS
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 10:03 AM
Strange Noise when accelerating! cybertees DIY / Maintenance / Service 22 05-24-2009 09:37 PM
Photo-Scavenger Hunt - THE LIST Black Yaris Photo-Video-Media Gallery 22 03-04-2009 09:35 PM
Black Yaris - Photo-Scavenger Hunt Black Yaris Photo-Video-Media Gallery 2 03-01-2009 05:13 PM
