Old 05-19-2009, 06:40 AM   #1
cybertees
Drives: Yaris 2000 plate 1.0
Strange Noise when accelerating!
Hi can any folks help?
When i press the accelerator, typically at higher speeds, but not always, i can hear a strange sound which i can best describe as a shhh noise but not an exact description, had exhaust checked and thats fine. There is no lose of power and seems to be running fine. Oil, water etc are all full. Only makes sound when i press he accelerator. Just noticed a strange noise when running slowly today also in 1st and 2nd gear, sounds a bit like a train lol!
Any ideas?
cybertees is offline   Reply With Quote
Old 05-20-2009, 04:48 PM   #2
TheSilkySmooth
TheSilkySmooth's Avatar
If you are using the Toyota made in Thailand Filter - get a WIX or NAPA on there right away - this is usually the hydraulic timing chain tensioner LOOSE letting the chain drag along the "nylon" chain guide around the front of the block - but only if you hear it in neutral with the door open and you rev it up. Otherwize it could be: tire squirm during acceleration. Choice #3, if you smell rotten egg (oxides of sulphur) while you are getting up to speed on the highway with the car floored - then the cat is getting carboned up. You havent done anything silly like seafoam treatment recently? Luck wid this, mang "V'
Old 05-20-2009, 04:49 PM   #3
TheSilkySmooth
Oh you have a one litre. Who da hell knows wid dat?!
Old 05-20-2009, 07:32 PM   #4
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
When it breaks you'll know what it is.We arent too familiar with the 1L engine so without more info we are only guessing,i'd think about checking the transmission oil.
Old 05-20-2009, 08:04 PM   #5
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
Sounds like your BOV isn't working correctly.... Check with toyota dealership.
Its a Chao!!!
Old 05-20-2009, 09:21 PM   #6
PhilD424
Drives: Red Yaris
Blow off Valve/Waste gate? How do you know he has a turbo? Unless BOV means something else.
-Phil
PhilD424 is offline   Reply With Quote
Old 05-23-2009, 09:34 AM   #7
TheSilkySmooth
I want a turbo!
Old 05-23-2009, 09:36 AM   #8
TheSilkySmooth
Yo, dis aint da WRX forum, mang!
Old 05-23-2009, 10:39 AM   #9
TheRealEnth
Beast
What do you mean.. oh Shi.. Oh man... gotta go
Its a Chao!!!
Old 05-23-2009, 01:24 PM   #10
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Must be the BOV.
Old 05-23-2009, 10:45 PM   #11
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Is that short for BOVine excrement?
Old 05-24-2009, 09:59 AM   #12
TheSilkySmooth
Hey stuck chain tensioners are a BIG problem on these cars. You'll destroy the motor if it remains that way for long. Seriously.
Old 05-24-2009, 10:39 AM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
it's the hampsters. they're out of breath
Old 05-24-2009, 12:42 PM   #14
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
I would check to see if the black hamster on the left side of the engine bay is okay^-^ My white one sprained his ankle
Honestly check your fender liners to see if one is loose.
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 05-24-2009, 01:25 PM   #15
helphelp911
Drives: yaris
Aww.. mine is make the same sound...
helphelp911 is offline   Reply With Quote
Old 05-24-2009, 01:28 PM   #16
helphelp911
Drives: yaris
Hi, thailand filer?? Do you mean the oil filter? i have no idea what toyota dealer put in my car when oil fill.
Old 05-24-2009, 01:28 PM   #17
helphelp911
Drives: yaris
Can you please tell me where is "black hamster"??
Thanks
Old 05-24-2009, 01:34 PM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
Thanks
left side of the engine bay, near the battery, but closer to the wheel
Belt noise? Cutie Pie #2 DIY / Maintenance / Service 20 05-22-2009 01:51 PM
Noise from the drums.... Lafiro General Yaris / Vitz Discussion 18 05-22-2009 09:49 AM
Transmission noise The little red pill General Yaris / Vitz Discussion 11 05-15-2009 01:26 PM
strange noise nisyota DIY / Maintenance / Service 7 03-05-2009 08:39 PM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 04:21 PM
