Old 02-06-2019, 12:57 PM   #1
mrgodai
Drives: Yaris Seden 2008
Yaris 2008 ALL tail/brake lights not working, replaced fuse and bulb already
USA Yaris 2008 Sedan.
So it starts off with passenger tail/break light not working at all.
I replaced the bulbs in both of them and still off. I put it off for a month. Now I went to check, ALL the brake/tail light are not working! even the high one by the window. I checked and replaced TAIL and PANEL1 fuses and still no go.
From what I read it's probably a wiring problem.
How do I use a multi-meter to check? and is there a guide for where the wires are and what panels I need to take off to check them?
Thanks in advance.
mrgodai is offline   Reply With Quote
Old 02-06-2019, 08:24 PM   #2
tmontague
tmontague's Avatar
Set your multi meter to DC volts then find your wire loom that goes to the lights that are not working. Simplest way is to start at the lights and work back. You will eventually fine that they all merge into one loom. There should be connectors along the way, disconnect them and ground your negative lead to the body if the car that you know is s good ground. Then take your red lead and test the pins in the connector and you should fine one is 12v when its given its signal (ie: brakes applied or 4 ways put on).
When you get to the first point where there is no power, look at the wiring or the connectors and you will likely find the issue. This is a simple way if you dont have wiring diagrams, but it is not as accurate
Old 02-21-2019, 09:23 PM   #3
SirDigby
Drives: 2007 yaris 3 door
i'm guessing it's the brake switch. or wiring to the brake switch. they are thin wires.
Old 02-22-2019, 08:25 AM   #4
dogsridewith
Drives: 2007 2-door hatchback
Do any of the lights on the rear end of the car work?
Old 02-22-2019, 11:28 AM   #5
bob225
Drives: Yaris
Brake lights are a very simple circuit do your sidelights, 4 ways and directionals work ?
If so i would throw a brake light switch at it
bob225 is offline   Reply With Quote
Old 02-22-2019, 05:54 PM   #6
dogsridewith
OP said tail lights also not working.
Old 05-10-2019, 11:35 AM   #7
Bart68
Bart68's Avatar
Drives: 2007 Yaris
Having the same problem, going to try and fix this morning.
2006 YARIS RS
Bart68 is offline   Reply With Quote
Old 05-16-2019, 07:12 PM   #8
Bart68
Bart68's Avatar
Drives: 2007 Yaris
I have tried everything I can think of and had a shop look at it, it's not the headlight switch, I have pulled my interior completely looking for a short in the wires, replaced the
headlight switch and now I find Rockauto sells a parking light control module for these cars
so I'm going to PnP today to try and find one of those.
2006 YARIS RS
Old 05-19-2019, 01:23 PM   #9
Bart68
Bart68's Avatar
Drives: 2007 Yaris
Found it today, the wire was pinched from the factory on the left side tail light, it finally
wore through and that is what caused my short. So anyone else who may have this
problem check the tail lights first..
2006 YARIS RS
Yaris 2010 beam lights not working in dash Riteshb DIY / Maintenance / Service 0 03-29-2018 03:05 AM
2015 Yaris Tail Lights Not Working TBowman Third Gen Yaris General Discussion 1 11-20-2016 09:44 AM
2012 yaris hatch rear interior light not working ironarmscott DIY / Maintenance / Service 0 09-19-2016 09:48 AM
Fog lights, or parking lights stopped working sylvermagyk DIY / Maintenance / Service 4 03-24-2011 06:13 PM
