Old 03-24-2011, 04:51 PM   #1
sylvermagyk
Drives: 2007 toyota yaris liftback
Fog lights, or parking lights stopped working
I really hope I am not repeating someone else's post, but there are so many threads, I couldn't find anything, so I am posting a new one. All of the lights in my 2007 Yaris liftback work except for the, well, foglights or are they called parking lights? The headlights both brights and norm work fine, my brake lights and rear lights work fine, the reverse lights are fine, all interior lights are fine, turn signals are fine, but the parking lights won't come on at all. I guess they aren't necessary because it passed inspection without them working. I think they are also called running lights. They would flicker on and off, and if I hit the side of the car would come back on, but now they are compeltely out. Is it just a bulb change, or could it be a fuse? And how would I fix either of those? Thanks!
sylvermagyk is offline   Reply With Quote
Old 03-24-2011, 04:59 PM   #2
Are you referring to the lights that come on when you turn the headlight switch one click?
If so, on the liftback there are two separate bulb on each side - One in the headlight assembly (referred to as the parking light) and the other is the little plastic chunk on the side of the front fenders (referred to as the side marker light).
If those are the ones you are referring to, do any of the four illuminate, and with the switch in that position are the taillights on?
Old 03-24-2011, 05:42 PM   #3
sylvermagyk
No and yes
None of the front four come on, but the tailights do. And yes that was exactly what I was referring to.
Old 03-24-2011, 06:07 PM   #4
It seems strange that all four bulbs would be out, but it's not a fuse since the tails work. I would pop one of the bulbs and see if there is power on one pin and a solid ground on the other. If so, then it really is bad bulbs.
Old 03-24-2011, 06:13 PM   #5
sylvermagyk
Thanks
I will have to have the boyfriend check that out for me, and I will get back to you.
Parking lights and Tail lights not working nerisahzn DIY / Maintenance / Service 16 01-16-2017 10:33 AM
Desperately Need Help Getting Fog Lights Working Again M4One DIY / Maintenance / Service 10 11-18-2010 04:28 AM
Taillights, signal lights, parking lights stop working jamal1984 DIY / Maintenance / Service 2 10-13-2010 11:17 AM
Has anyone tried taping into the parking lights for fog light installation (safe?) YarisSedan DIY / Maintenance / Service 14 03-20-2010 05:49 AM
my Projector Fog lights project ezhacker1 Cosmetic Modifications (Exterior/Interior) 3 01-10-2010 06:21 PM
