Old 01-01-2010, 12:55 AM   #1
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
my Projector Fog lights project
After getting the OEM fog lights working, i pretty much hate the light output it gives, light is scattered up not very good or the intended usage. I am sure it would be worse with HID in it, so i embarked on finding a cheap but good fog light projector.
My project is almost done:
Blazer Projector fog lights next to OEM
Bulb comparison: H11 to 894 *note H11 is 55w, 894 is a 37.5w
The fog light mounted with 2 L brackets to the OEM assembly screw placements
Took a little while to get it centered in the hole, its actually a little bit more complicated than just a simple L bracket
3500k HID in left side, right side OEM fog and bulb
2 pictures to compare cutoff and light dispersion on ground, you can see how OEM even tho aimed all the way down still blinds.
Heres a pic of cutoff from the side
I will finish the right side by tonight, i might retrofit it into the OEM fog assembly, might not, i could just sell those things instead of destroying it, cuz these fog lights are too long to put into the, like an easy retrofit.
Let me know what you guys think, sorry for the crappy cellphone pics.
Check out my Build thread:
Old 01-10-2010, 01:48 AM   #2
ezhacker1
ezhacker1's Avatar
bump, for the edit
Old 01-10-2010, 09:18 AM   #3
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
props on the out of the box thinking BUT those h11 bulbs can be had in other wattages(if thats a word) as well. i have 80w LUMINATIC JDM YELLOWS in mine and their bright as hell.
Old 01-10-2010, 05:21 PM   #4
ezhacker1
ezhacker1's Avatar
sure it comes in more watts, but the light is just horrendously scattered.
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
BIG driving lights.... how? jonismyname Cosmetic Modifications (Exterior/Interior) 22 09-30-2010 07:54 AM
Fog Lights Poll Reeves360 Cosmetic Modifications (Exterior/Interior) 14 12-27-2009 02:00 AM
Tail lights for 09 sedan piepie Cosmetic Modifications (Exterior/Interior) 7 06-03-2009 09:24 AM
Re-did lights, fixed scratch, RR floor mats! lots-o-pics dg4rez Photo-Video-Media Gallery 15 04-21-2009 01:45 AM
