#1 |
![]() Drives: Yaris T3 Join Date: Dec 2009
Parking lights and Tail lights not working
Hi guys,great forum. I've just purchased a 2007 hatch for my wife about two weeks ago. Everything was fine until yesterday when she noticed that the tail lights were not working. I've checked every fuse under the hood but still no joy. is there anything else theat could have gone wrong. any help woul be appreciated.
#2 | |
#3 |
thanks a lot. finnaly got it working
#4 |
Drives: Toyota Yaris T1 Join Date: Aug 2012
Hi, I have the same problem but I find no fuses labeled "TAIL" in my secondary fuse box under the dash. All the fuses seems fine as well. Any alternative ideas?
#5 |
What year is your T1?
#6 |
![]() ![]() Drives: 07 Toyota Yaris Hatch-Back Join Date: Jul 2010
if all fuse are working fine then it maybe the bulbs are dead, which means u might have to replace the bulbs....
#7 |
SRacer
so what happens if only one side of the brake light works and not the other? can that still be the fuse?
"If I go down, I do time. I do real time. I don't know about your other drivers but when I see flashing lights in the mirror I don't stop." - Dominic, Fast & Furious ![]() Learn The Truth about Six Pack Fast! |
#8 |
No. One fuse drives both, so that is most likely a bad bulb.
#9 |
![]() Drives: Toyota Yaris Join Date: Oct 2015
No tail lights
No tail lights working front or rear on my Yaris, no warning sound when light switch left on and door opened, no front or rear fog lights. All other lights working.
All fuses and relays checked out ok by auto electrician but he didn't have time to do a full check of system. Any ideas anyone? |
#10 | |
#11 |
Tried that and panel 2 fuse but still no lights.
#12 |
![]() ![]() ![]() ![]() Join Date: Feb 2010
Bad switch? Check all grounding points. also, did you add anything like trailer hitch wiring?
#13 |
Nothing added. Lights just stopped working. Where would I find the grounding points?
Anyone have the link to a video on cleaning the contacts in the light stalk? Saw it mentioned in a thread but couldn't find a link. |
#14 |
You said that all other lights work - So, the headlights come on, but the tails, fogs do not?
Does the indicator come on in the cluster? Does your Yaris have daytime running light?
#15 |
Drives: Toyota Auris Join Date: Dec 2016
I am having the same problem guys please help
#16 |
![]() Drives: toyota yaris 2007 Join Date: Jan 2017
I have exact the same problem on my toyota yaris 2007- my park lights,dashboard light, member plate aren't working I have checked fues is not blown ,bulbs still ok.Now fuel guege is not working properly(mixedup)
#17 |
| DIY LED Tail (Rear) Head Lights | dg4rez | DIY / Maintenance / Service | 11 | 12-21-2009 04:10 AM |
| Smoked tail lights: film, paint or replace? | Herbicidal | Cosmetic Modifications (Exterior/Interior) | 30 | 10-19-2009 02:01 PM |
| Tail lights for 09 sedan | piepie | Cosmetic Modifications (Exterior/Interior) | 7 | 06-03-2009 09:24 AM |
| JUST GOT MY JDM TAIL LIGHTS!!!!! | falkor_99 | Cosmetic Modifications (Exterior/Interior) | 12 | 10-01-2007 11:25 AM |
| FS: Yaris Liftback Tail Lights Stock OEM | tekmoe | Items for Sale by private party | 5 | 06-15-2007 11:57 PM |
