Old 10-30-2009, 08:56 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Multiple cylinder misfire under boost
Several months ago at an autox event, while under boost the Yaris posted a CEL and went into limp mode in the middle of the race. The codes showed misfires on multiple cylinders. Fortunately, the CEL cleared and the car ran fine if I stayed out of boost.
When I pulled the spark plugs, they were all coated with a dry reddish deposit. Today I put in a fresh set and the car runs as well as it did right after the blower was installed. The SC typically puts out 7lbs of boost. I use Shell V-Power gas at 91 octane.
What causes this type of deposit? The plugs are NGK BKR7EIX Iridium with a heat range of 7. The plugs have been in since December of last year.
I'm also running a set of 1ZZ injectors. AFR stays at 14.7 under normal driving conditions and then goes to 11-12 under boost.
Old 10-30-2009, 10:17 PM   #2
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
fuel with additives
Old 10-30-2009, 10:20 PM   #3
LtNoogie
LtNoogie's Avatar
Maybe I'll try someone else's 91 octane for a year and keep checking the plugs.
Old 10-30-2009, 11:07 PM   #4
isn't 14.7 a bit lean?
Old 10-31-2009, 12:47 AM   #5
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
It looks slightly rich, which is because of the 11-12 AFR. The deposits probably cause the misfire and replacing the plugs is the best thing to do. Probably best to replace plugs on a regular basis.
Old 10-31-2009, 02:14 AM   #6
Ten months on a boosted car is pretty long for plugs. I would check them more often.
What is the gap?
Old 10-31-2009, 01:56 PM   #7
LtNoogie
LtNoogie's Avatar
What? Replace Iridium plugs every year or sooner? If I'd known that owning a S/C was this expensive, I... just kidding.
Thanks for all the suggestions. It's running great with a new set of Iridiums.
Not to save money, but I'm going to Harbor Freight to get one of those spark plug blasters. I've always wanted to see how well they work.
Old 10-31-2009, 01:57 PM   #8
LtNoogie
LtNoogie's Avatar
Originally Posted by camelll View Post
Noogie that would be from octane booster or fuel additives. My plugs looked similar to yours.
Mike, what kind of gas do you use. With enough data points we can show what brands of gasoline leave what kinds of deposits. I've been using Shell V-Power exclusively. I put in one can of octane booster every other month on race day.
Old 11-01-2009, 02:12 AM   #9
yaris-me
Learn to Relax
If I'm not mistaken you'll also need an air compressor. If you buy an air compressor, buy one with enough capacity to run air tools, like paint gun, impact wrenches, etc... Then I'll come over and work on my car.
Old 11-01-2009, 11:20 AM   #10
cdydjded
Drives: Yaris LB Turbo
Red to purple deposits on one side of the core nose are an indication of a fuel additive. While many of these deposits are non-conductive and do not contribute to lack of performance, some fuel additives contain octane boosters that leave conductive deposits on the core nose. Care should be taken to select fuel additives which are compatible with ignition systems and do not contain conductive materials such as octane boosters.
Old 11-01-2009, 02:40 PM   #11
LtNoogie
LtNoogie's Avatar
I have such an air compressor. Let's plan a weekend to work on your car.
Old 11-01-2009, 11:57 PM   #12
yaris-me
Learn to Relax
Just Joking. I only need to do electrical work right now.
Old 11-02-2009, 12:47 AM   #13
Race day? Did someone say race day?
Old 11-02-2009, 05:44 AM   #14
N3misiS
N3misiS's Avatar
Drives: Yaris T1 1KRFE
Interesting, I just Turbo'd my car, there is a post...
It is good to know as I am also runing NGK Heat range 7 but the spark plugs are for the
1krfe 3cyl....
As far as I know fuel aditives is a no no, the cr*p they put in there is unbelivable sometimes, here is South africae we are quite lucky we can choose 93, 95, and 102.6 octain fuel for race day....
Have a look at my post, I found some stuff maybe worth mentioning.
“Do or do not... there is no try.”
N3misiS is offline   Reply With Quote
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 02:05 AM
misfire on no 1 cylinder beemer dave DIY / Maintenance / Service 9 05-25-2009 09:13 PM
Supercharger Selection and Limiting Boost Nexus1155 Forced Induction Forum 1 12-01-2008 04:51 PM
DIY Hood Cylinder churp Cosmetic Modifications (Exterior/Interior) 46 06-25-2007 06:46 AM
Canada Only - Maybe a $1000 enviro rebate on Yaris> MDF New YARIS Purchase Forum 45 05-01-2007 09:17 PM
