Old 05-22-2009, 05:28 AM   #1
beemer dave
Drives: 1.0 vvti 2001
misfire on no 1 cylinder
Since I bought this 1.0 01 car, the engine management light has been on.
Diagnosed on basic machine as misfire on no 1 cylinder. Checked coil which is fine. New plugs fitted and currently trying injector cleaner in fuel.
Wonder if its a sticky valve. Idle is rough and doesn't pull away cleanly. Its fine and smooth above around 1500 rpm. I'm a bit lost as to what to do next apart from expensive trip to main dealer!
beemer dave is offline   Reply With Quote
Old 05-22-2009, 06:35 AM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
If its got a check engine light on then it should be throwing a code to the OBD11 computer ,plug in a code reader and see what code is showing up.
not sure how you know its the No.1 cyl giving problems but if you've changed Coil,plug wire and plug it may not be the problem,a bad valve would either show some smoke blowby through the exhaust or oil contamination of the plug or it would be making some kind of noise.
Old 05-22-2009, 09:11 AM   #3
missfire code can also mean it's not firing at all. Upon a cylinder not working, IDLE will be rough, car will lack power and gas consumption will raise.
that's all i can tell.. i guess..
Old 05-22-2009, 10:37 AM   #4
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Isn't the 1 litre a 3 cylinder engine? If it is, you're running on two cylinders...
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 05-22-2009, 11:39 AM   #5
jambo101
jambo101's Avatar
Your math is 100% correct
Old 05-22-2009, 11:52 AM   #6
looks like the 1SZ-FE is a 4cyl engine!
Old 05-22-2009, 12:39 PM   #7
cleong
cleong's Avatar
Yes you're right, its a 4 cylinder - I got it mixed up with the 1 litre the Toyota Aygo has!
TRD Blue brake pads
DC Sports header
Old 05-22-2009, 10:58 PM   #8
severous01
hey, how about checking your valve and lifter lash....it's on the hood. you need a feeler gauge.
Old 05-23-2009, 09:30 AM   #9
TheSilkySmooth
TheSilkySmooth's Avatar
Do a compression test first. Also, The coil may look OK and have the specified impedance but still be bad due to dielectric breakdown. Luck on this one, mate.
Old 05-25-2009, 08:13 PM   #10
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
map sensor output would be a good place to get a better idea of whats causing a misfire. if only one cyl. is misfiring... fuel psi/ clogged injectors and egr port clogging are unlikely but not impossible, however ignition side issues (coil pack/plug) or vacuum (bent valves) issue could be a more likely cause. there must be a diag troubleshooting chart for misfire on cylinder 1 in the service repair manual. if not check injectors, swap cyl 1 with cyl 2 and see if the misfire switches cylinders as well. do the same with the coil packs and spark plugs. those are some simple quick checks. then try a leakdown test on the misfireing cylinder see if its out of spec. good luck!
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Misfire and engine light Gazdaman DIY / Maintenance / Service 5 01-03-2009 09:20 PM
DIY Hood Cylinder churp Cosmetic Modifications (Exterior/Interior) 46 06-25-2007 05:46 AM
Canada Only - Maybe a $1000 enviro rebate on Yaris> MDF New YARIS Purchase Forum 45 05-01-2007 08:17 PM
