Old 01-03-2009, 06:47 PM   #1
Gazdaman
Drives: Corsa 1.2 8v
Misfire and engine light
Hi guys, first post but I'm in need of some help.
My girlfriend has a 99 Yaris 1.3 vvti and for about a year now, it's had the engine light on.
We took it to a garage soon after it came on and they just turned it off.
Anywho, about 6 months ago it started misfiring when really cold and at certain revs. Normally really high, or really low.
Now I'll assume some sensor has gone, like an air flow, or lambda or something like that. (New fangled electronic cars!).
So how can I read the error code? I've read about bridging connections and reading error codes off the rev counter. Can that be done on a Yaris?
Do the symptoms sound like anything obvious?
Thanks
Gaz
Gazdaman is offline   Reply With Quote
Old 01-03-2009, 08:39 PM   #2
well, you can buy OBD2 code readers online, i wager (i got mine locally at an auto parts store)....shouldnt be too much more that 100USD online plus shipping....
how do you know its misifiring? typically misfires are a blinking check engine light....
Old 01-03-2009, 08:44 PM   #3
Gazdaman
Well, I say misfire. I've only diagnosed mis-fire from previous experience. It's how it feels.
It feels like the car's holding back. If you come off the throttle and get back on, it normally sorts it. Or come slightly off full-throttle.
So I need an ODB2 scanner?
Gaz
Old 01-03-2009, 08:48 PM   #4
if you want the read the code, ya
your car being a 99 it should be obd2....theres like a jack/port under the dash near your steering column....
Old 01-03-2009, 09:12 PM   #5
Gazdaman
Lovely thanks. I'll see if I can borrow one. If not I'll buy one (after checking for this port).
Then I assume it'll tell me what's wrong, and I'll get my hands dirty and fix it.
Gaz
Old 01-03-2009, 09:20 PM   #6
Gaz
itll tell you the code and they usually come w/ a book to tell you what the code generally means...THEN you can fix it, lol
