![]() Drives: 2010 yaris Join Date: Nov 2009
2010 hid problem
hi im new to yaris world i needed some help, i just got some hid it has a high and low beams. whenever i plugged it up only the high beams worked, i heard alot of people have trouble because of DRL but i have a button to turn it off. can this be the problem to my lowbeams not working??
I love momentum.
If it were me I would pull the DRL module. It took me 10 minute to remove the module from my car. Easy.
The Beautification of Car
i did searched it. i got the bi hid for hi n lo beams but the lows beams are still not working anybody had a problem like this?? ive tried a couple hours trying to get it to work. no luck =/
#7 | |
http://www.yarisworld.com/forums/sho...isable+daytime |
#8 | |
In the first post you mentioned a button to turn off the DRL. Is there actually one or was that button something else? The EWD's for 2010 show the headlight related wiring to be the same as prior years. They still show the DRL module, but like prior years mention it as being optional.
i would check the wiring for the hid's....
what kind of hi/lo setup did you buy? bixenon? or halogen high beams? ballasts hooked up correctly?
| HID Kit High-Beam Cluster Indicator Problem | Split | Cosmetic Modifications (Exterior/Interior) | 21 | 07-24-2010 06:50 PM |
| HID flickering problem - DRL fog - Problem solved. | IllusionX | Cosmetic Modifications (Exterior/Interior) | 9 | 10-01-2009 07:37 PM |
| HID problem | hex_yaris | Cosmetic Modifications (Exterior/Interior) | 3 | 01-03-2009 12:35 AM |
| HELP!! HID problem | 07yaris_fe | General Yaris / Vitz Discussion | 2 | 11-20-2006 07:00 AM |
