Old 11-19-2006, 07:09 PM   #1
07yaris_fe
Drives: 07 Yaris HB RS
Question HELP!! HID problem
I have installed H4 6000k hid kit
and i did disable the DRL relay
Installed the kit for 5 months, with no problem
but today when i was driving, the light suddenly went off
tired to turn on again, doesn't work then i park aside and take a look
then i turn off my car, open hood and check it out
nothing have problem, checked connection, no problem
then i try turn on my light, then it work
so please help, anyone know why this happen?
do i need to change bigger fuse for the light?
if yes, which and where i can do that?
or any other way to get this fit????
please help, thanks
07yaris_fe is offline   Reply With Quote
Old 11-19-2006, 10:06 PM   #2
spkrman
Drives: 1
sounds like a weak connection somewhere in there... go over everything with fine tooth comb
Old 11-20-2006, 06:00 AM   #3
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Not the fuse or it would have blown. The connection may have been loose and when you checked it, you took care of that. You may want to try cleaning the connection with alchohol.
Gas pedal problem? Befuddled Performance Modifications 28 01-27-2010 09:55 AM
Is aftermarket HID kit legal (in NJ)? Jfoofoo Cosmetic Modifications (Exterior/Interior) 25 03-19-2009 02:05 PM
Closest to a HID kit? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 62 03-18-2009 12:44 AM
My 6500k H4 HID Review [pics] Chris07LB Cosmetic Modifications (Exterior/Interior) 74 10-10-2006 07:19 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
