Old 12-22-2009, 10:47 AM   #1
phenoyz77
http://www.lifeline-mts.
Drives: yaris
dash board rattles
just his morning this "rattles" are coming from the dashboard
somebody had this before
phenoyz77 is offline   Reply With Quote
Old 12-22-2009, 11:41 AM   #2
Hershey
most likely your display . Fixed ours with sticky back felt . Will need to remove pieces located on both sides of climate control knobs and then the plastic part of upper dash that meets the display . There are a few screws that hold display unit in place . Then put sticky back felt on tabs that touch dash . Found it easier to sit on opposite seat to remove the pieces on side of climate control knobs by pulling out towards you ( pull left panel gently towards you when sitting in passenger seat , right when seated in driver seat ) . Be careful not to break off the tabs . Rattles are annoying . Seem to be the worst on the coldest days ( plastics constrict and are stiffer ) and warmest days ( expands touching other parts and weaker from strong sun ) . GOOD LUCK
Old 12-22-2009, 05:08 PM   #3
phenoyz77
Drives: yaris
do you have a picture DIY for this
thanks
Old 12-23-2009, 01:26 AM   #4
phenoyz77
Drives: yaris
my bad, its not the dash board , its the aftermarket rear view mirror
i put-in that's making the rattles
Old 12-23-2009, 04:33 AM   #5
sqcomp
Roadrunner Jr.
sqcomp's Avatar
It could be any of those plus other things. I speak from experience. Look to either side of the dash near the doors as well. I have a sound deadening primer in the ICE section of this forum if you want to see a little bit into the car.
I'll be tearing the dash down in April/May when I get back home from Iraq here. I've got some things to do.
― Thomas Paine
Old 12-23-2009, 10:45 AM   #6
phenoyz77
Drives: yaris
thanks bro...
Old 12-22-2009, 03:01 PM   #7
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
Thanks for the tip, I need to do this despite having the TSB done which was a foam pad placed under the display-still getting a cold morning rattle.
UTVitz is offline   Reply With Quote
Toyota Silver Dash Kit Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 72 04-13-2012 01:42 AM
Trade upgraded radio and dash for base radio and dash??? Yarisguy13 Items for Sale by private party 4 09-17-2007 06:32 PM
Brighter Dash lights, there is a switch??? mgthompson General Yaris / Vitz Discussion 14 04-04-2007 08:51 AM
dash problems...help needed foggy08 DIY / Maintenance / Service 1 01-25-2007 08:04 PM
