#1 |
![]() Drives: yaris 1.0 Join Date: Jan 2007
dash problems...help needed
the digital dash on my 2001 yaris gs keeps going out .....i went to a breakers and tried a new dash. it lit up ok but it didnt show the mph or revs also it showed my fuel tank as being full when i knew it was only half full....the guy at the breakers said mr toyota might have to set the dash up with the ecu.....is this correct? if so how much would this cost ? or will they have to sell me a new dash as well ?
I drive a yarrrris
Drives: 07 Sedan Polar White Join Date: Sep 2006
you might want to try the breakers again and after hooking up the new cluster pull the batt cable for a few secs and then hook it backup to "reset" the ecu
![]() Docotrs say all the drikning has mesesd up my seplilng and radieng will work for parts |
| Dash Kit - No Mods | barryware | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 09-14-2014 03:59 PM |
| Good place to find constant & switched 12V behind dash? | atebit | In Car Entertainment + Electronics (audio / video / alarm) | 16 | 03-03-2009 10:40 AM |
| Differences in dash between sedan and HB | sroberts | General Yaris / Vitz Discussion | 13 | 11-16-2008 10:34 PM |
| Timing chain, sprockets, & cam position sensor problems? | PetersRedYaris | DIY / Maintenance / Service | 8 | 01-04-2007 11:50 AM |
| How do I take apart dash on left side? | ryker | DIY / Maintenance / Service | 5 | 01-01-2007 05:01 PM |
