Old 11-25-2006, 08:19 AM   #1
atebit
Drives: 07 Yaris Sedan
Good place to find constant & switched 12V behind dash?
I'm looking to add some additional accessories to my 07 sedan that require constant/switched 12V. I thought about using vampire taps on those wires that supply my alpine HU, but I don't want to end up drawing too much current through them.
I was thinking about mounting this device on the drivers side, right above the little "pocket" opening on the dash console near the driver's right leg. Is there an easy place to grab constant/switched 12V from in that areas?
atebit is offline   Reply With Quote
Old 11-25-2006, 09:48 AM   #2
Wayside
Wayside's Avatar
Drives: 07 yaris 5spd sdn
Try the fuse box. There should be a couple open 'slots' depending on your vehicles options. A voltage tester is your best friend...
Wayside is offline   Reply With Quote
Old 11-25-2006, 02:46 PM   #3
drell42
Drives: Blank
the cig lighter has a switched that I used for my radar!
drell42 is offline   Reply With Quote
Old 11-25-2006, 07:43 PM   #4
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Go to the fuse box and use one of these:
http://www.grote.com/cgi-bin/goc/goc...number=82-2212
Available at Auto Zone.
Old 11-26-2006, 07:27 PM   #5
atebit
Very cool...I'll give one of those a try. I just hope some of those positions that are marked with a "/" on the fusebox cover are active...
Old 11-26-2006, 07:32 PM   #6
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Originally Posted by Violin
haha, i cant get enough of that damn pic, not sure if i said or not but - great find violin
as far as switched and constant sides of the fuse - the side (of the fusebox) closest to the engine offers constant power where the other side is switched on and off with the key (atleast my sedan is that way)
will work for parts
Old 02-21-2009, 09:20 PM   #7
expo2
Drives: 2008 Yaris HB
I mounted a telephone wall-mount recpt in the consule pocket next to the passenger's legs. It powers off the power recpt/cig socket. I plug my Bel 955 rd into it because the radar detector has a telephone plug-style connector (RJ-11?).
expo2 is offline   Reply With Quote
Old 02-21-2009, 09:44 PM   #8
POORSHA
POORSHA's Avatar
Drives: 2008 LB
There is acc power constant power illumination and ground available behind the gage cluster. The wires power the clock.
POORSHA is offline   Reply With Quote
Old 02-23-2009, 11:18 AM   #9
hola! old thread :)
well, just incase you guys didn't know. The yaris has constant +12v at anything you plug in. Use the ground point of your choice and you have power!
just beware how much power you are pulling from that fuse.
Basically, the cig lighter is always on, cept you need to ground it elsewhere when the ignition is not to "on"
Old 03-01-2009, 09:16 AM   #10
yaris prime
Yes- I fit in it.
yaris prime's Avatar
Drives: 2007 Yaris liftback, MT
So, where would be a good place to tap for the A1 aftermarket window and locks kits. I emailed A1 and according to them, you need 10-20amps for the locks, and 15-20 for the windows.
I'm surprised it doesn't have a pull-start !
yaris prime is offline   Reply With Quote
Old 03-01-2009, 11:53 PM   #11
through the firewall and to the battery :)
Old 03-02-2009, 09:36 PM   #12
yaris prime
Yes- I fit in it.
Anbody know the best place to go through the firewall for this?
Old 03-02-2009, 10:47 PM   #13
There is a large bushing through the firewall, just behind the fuse panel. It has plenty of space to poke holes through it without nailing the harness. It's in the middle of this pic:
Old 03-03-2009, 09:01 AM   #14
yaris prime
Yes- I fit in it.
Awesome, thank you.
Old 03-03-2009, 10:05 AM   #15
goku87
goku87's Avatar
Drives: Black HB
can you attach that image to a post? photobucket is blocked. thanks.
Old 03-03-2009, 10:13 AM   #16
Here you go:
By the way, the other side of the bushing is behind the battery. It is easiest to poke through from the dash side, and then find your wire under the hood...
Old 03-03-2009, 10:40 AM   #17
goku87
goku87's Avatar
Drives: Black HB
Here you go:
Attachment 20001
awesome. thanks. thats high value info right there!
