Old 01-30-2016, 07:36 PM   #1
sarabjeet19
Drives: 2007 Yaris Hatchback
Thumbs down P/S, Airbag lights on, Radio,fan,brakes light stopped working.
I have 2007 Yaris hatch back Automatic.
I have following issue with my car and spend all day to fix it
1. PS + Airbag light on, steering is freeze
2. Car is in parking mode, can't put it in drive
3. Radio, Fan, Signal,brakes lights all has stopped working
I disconnected the battery and then ps light was gone but battery light was their after restarting the car... all lights were working after that... I turn off the car and restart it, its again went back to ps light on with no powers to cd,signal,brakes etc...
I have checked all fuse,they are good. Not battery is disconnected and connect few time,but noting is happening. Please help..thanks in advance
sarabjeet19 is offline   Reply With Quote
Old 01-31-2016, 04:06 AM   #2
bairjo
What maintenance work or modification were you doing when this started?
bairjo is offline   Reply With Quote
Old 01-31-2016, 09:08 AM   #3
nortonfb
Drives: 2007
With the key on, not running, can you move the steering wheel?
If no, have you tried jiggling the wheel and turning the key to make sure the wheel is unlocking.
Is there any noise from the belt?
Did you use a meter to check the fuses?
nortonfb is offline   Reply With Quote
Old 01-31-2016, 11:58 PM   #4
sarabjeet19
Thanks for reply guys..!!!
Actually positive battery terminal went bad, I fixed it by soldering a new wire and trespass the fuse, its perfectly fine now... I found soulution form given link by CTScott
http://www.yarisworld.com/forums/showthread.php?t=28729
Thanks CTScott, once again you saved me..
Old 02-01-2016, 12:00 AM   #5
sarabjeet19
Fixed everything, positive battery fuse terminal was the issue...
thanks CTScott for your kind feedback and suggestions.
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Electrical Problems PS,A/C,RADIO,SPEEDOMETER,SIGNALS,AIR BAG LIGHT ON, ALTERNATOR toystory DIY / Maintenance / Service 43 04-17-2021 05:54 AM
Battery Warning Light - Different Twist maybe RutherfordmanX DIY / Maintenance / Service 3 06-08-2015 09:59 PM
Brake / Signal Light Issue PtahX DIY / Maintenance / Service 2 12-02-2014 09:57 PM
airbag light clockspring replacement issue maui DIY / Maintenance / Service 6 09-22-2014 10:09 PM
