![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
With the key on, not running, can you move the steering wheel?
If no, have you tried jiggling the wheel and turning the key to make sure the wheel is unlocking. Is there any noise from the belt? Did you use a meter to check the fuses? |
#2 | |
Drives: 2007 Yaris Hatchback Join Date: Nov 2015
http://www.yarisworld.com/forums/showthread.php?t=28729 thanks CTScott for your kind feedback and suggestions. |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| Electrical Problems PS,A/C,RADIO,SPEEDOMETER,SIGNALS,AIR BAG LIGHT ON, ALTERNATOR | toystory | DIY / Maintenance / Service | 43 | 04-17-2021 05:54 AM |
| Battery Warning Light - Different Twist maybe | RutherfordmanX | DIY / Maintenance / Service | 3 | 06-08-2015 09:59 PM |
| Brake / Signal Light Issue | PtahX | DIY / Maintenance / Service | 2 | 12-02-2014 09:57 PM |
| airbag light clockspring replacement issue | maui | DIY / Maintenance / Service | 6 | 09-22-2014 10:09 PM |
