Old 04-09-2010, 07:30 PM   #1
yairs rear wiper mod
this also applies to Prius and maybe some other models too.
http://www.youtube.com/watch?v=50btxtAuHfE
Old 04-09-2010, 07:43 PM   #2
thanks
Old 04-09-2010, 07:47 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Weird that the tab is on there in the first place... Thanks for the vid!
Old 04-09-2010, 07:49 PM   #4
darthbauer
Not really here...
darthbauer's Avatar
Oh that is so getting done right now, brb..........
Liberate Tutemet Ex Infernis.
Old 04-09-2010, 07:53 PM   #5
Billiam
Drives: '10 White Yaris 4D LB
First time I saw this mod was about 6 years ago on a Sienna forum. It was done the first day I brought the van home in 2004. It was also the first mod I did to the Yaris as well.
Old 04-09-2010, 07:58 PM   #6
darthbauer
Not really here...
darthbauer's Avatar
...and done.
Old 04-09-2010, 08:21 PM   #7
zerofade
zerofade's Avatar
Drives: 2008 yaris Factory
Send a message via AIM to zerofade
why not just pull the clip off when you want to clean the window
zerofade is offline   Reply With Quote
Old 04-09-2010, 08:21 PM   #8
MadMax
MadMax's Avatar
I could've sworn I learned about this mod on this forum, it was one of the first things I did to my Yaris when I got it...
Old 04-09-2010, 08:58 PM   #9
spookz
JDM yO!
Drives: '09 3dr. 5-spd
My Yaris can already do that, my cover doesn't come with the tab from factory. I wonder if it's a 06-08->09 change, or due to region differences.. but nice work Garm!
Old 04-09-2010, 10:25 PM   #10
One note on doing this - Watch out when you wash your car. I have now poked myself in the eye three times while washing the car with the wiper flipped outwards.
Old 04-10-2010, 12:07 AM   #11
COULD it be to stop turbulence from allowing the wiper to be lifted up at highway speeds? Just a thought that ran through my head
Old 04-10-2010, 12:51 AM   #12
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Drives: 09 Polar White HB
i dont think there is enough turbulence in that area being so close to the body and in the "bubble" area to lift the wiper
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires!
| UR 19mm sway |
Cosmonaut is offline   Reply With Quote
Old 04-10-2010, 03:40 AM   #13
RedRide
RedRide's Avatar
Good point.
Personally, I have mixed feelings about this mod.
When the wiper arm swings out you have to be carfull the wiper blade assembly doesn't disengauge from the arm.
I suspect that this is the purpose of the "tab".
Old 04-10-2010, 04:22 AM   #14
1. removing the base cover every time is inconvenient, and eventually the cover will become worn and will fall off. I'd rather do a simple, free mod and have no more problem.
2. I've never been "careful" about the wiper blade assembly, and on the three cars we have with the mod, it's never disengaged.
CTScott, I think it's a safety concern for Toyota, as you've pointed out.
Old 04-10-2010, 09:02 AM   #15
nemelek
DWEED
nemelek's Avatar
Nice idea.
Old 04-10-2010, 10:20 AM   #16
Billiam
There isn't. 6 years on our Sienna and 1 month on the Yaris. Perfectly simple mod that causes no ill effects.
Old 04-10-2010, 03:00 PM   #17
MadMax
MadMax's Avatar
Yeah, I've had mine like that for almost a year and a half and it hasn't been a "safety issue." As a matter of fact, every hatchback I've owned has had the ability to lift the wiper off of the rear glass; which is why I found it odd that the Yaris didn't and discovered this easy mod to fix that!
About the only issue it's caused me is forgetting to put the wiper back down after cleaning the car!
Cheers! M2
Old 04-10-2010, 04:26 PM   #18
if it's a safety issue, a highway speed issue, or whatever, why is this tab present only in North American cars? Mine has a variable geometry wiper arm-enabling cover (gotta make it sound fancy) from the get-go.
Sounds to me like another consumer protection thing, after all, if an erudite member like CTScott pokes himself in the eye with the wiper, someone would find a way to sue Toyota for it....
DIY - Standing rear wiper for hatchback sex DIY / Maintenance / Service 42 10-17-2018 07:32 AM
Removing rear wiper fred812 Cosmetic Modifications (Exterior/Interior) 34 01-27-2013 01:22 AM
Found A Rear Wiper Blade Replacement jeff618 DIY / Maintenance / Service 8 11-03-2011 11:15 PM
Yaris Hatchback Rear Window Wiper Attachment? New! paguy717 General Yaris / Vitz Discussion 2 11-22-2009 03:31 AM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 11:30 AM
