Old 11-08-2009, 10:17 AM   #1
sex
sex's Avatar
Drives: 09 5DR
DIY - Standing rear wiper for hatchback
Story:
The rear wiper is a shelf for dirt. During the winter months, I suspect it'll clear snow more effectively by pushing it down instead of bunching it to the side. This took about 30 minutes and is easily reversible.
Tools:
1. 10mm socket - used on wiper arm and motor
2. #2 Phillips screwdriver - used on motor
3. Slotted screwdriver with tape - used to pry trim panel
Procedure:
1. Remove rear wiper arm (refer to service manual pg WW-29).
2. Pop off the back door trim (refer to service manual pg ED-142).
3. Disconnect the white power plug from the wiper motor.
4. Remove the three bolts holding the motor.
5. Remove the four screws off the cover plate.
6. Lift the long arm off the white gear.
7. Rotate the short arm to the left and reconnect the long arm.
8. Reassemble and enjoy.
Old 11-08-2009, 10:58 AM   #2
chongopants
Drives: 2007 Yaris Hatchback
Send a message via AIM to chongopants Send a message via MSN to chongopants
do you have a before and after pics? and what size bolts and what not.... it would be a great how to and you got most of it already here...
chongopants is offline   Reply With Quote
Old 11-08-2009, 10:59 AM   #3
chongopants
If you dont want to do it I gotta do mine soon, and I think it would be a good addition to the DIY section.
Old 11-08-2009, 11:59 AM   #4
YAR1S
YAR1S's Avatar
Whats the purpose of having the wiper stuck up all the time .......?
-Jen <3
Old 11-08-2009, 12:01 PM   #5
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
I'm with you. I don't see the advantage.
Old 11-08-2009, 12:01 PM   #6
chongopants
Im going to remove the wiper myself and have the hole filled, and there are plugs at the hardware store that can be painted that fit right in the existing hole. Or in my case I am gonna have it filled when I have some body work done.
Old 11-08-2009, 12:13 PM   #7
YAR1S
YAR1S's Avatar
meh... I'd fill mine in but most of the time I need it to work.... I'd rather have a DIY for intermittent wipers.... which I think we already have one...haha
-Jen <3
Old 11-08-2009, 12:15 PM   #8
chongopants
Yeah, i haven't seen anyone with a set that really works properly, to me it feels like an afterthought by toyota, it doesn't even stay on the glass and is noisy... worst feature of the car in my opinion. Plus I am all for weight loss on this car, and thats another 5 or so pounds not needed.
Old 11-08-2009, 12:30 PM   #9
2009BBPliftback
2009BBPliftback's Avatar
I find my rear wiper useful now the one on my scion xb was crap!
2009BBPliftback is offline   Reply With Quote
Old 11-08-2009, 12:36 PM   #10
chongopants
Well thanks for the input guys but for me I think out is the best for me. I like the look and the weight loss, I count it all now. I am gonna change batteries and a few other things too, the car drives unlike any yaris I have driven. It is loose still but I haven't stiffened the suspension yet.
Old 11-08-2009, 02:36 PM   #11
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
It doesn't gather dust and dirt when it's sitting that way versus the stock horizontal position. My wiper blade collects a ton of nastiness, I cringe sometimes if I have to use it since it'll spread it over the back window.
Old 11-08-2009, 10:07 PM   #12
sex
sex's Avatar
Drives: 09 5DR
Added tools and story section. I had reservations about it interfering with my rear view but it's barely noticeable after a few days. Since I live in a dusty area, there's less build-up.
Old 01-17-2011, 09:58 PM   #13
MadMax
MadMax's Avatar
Just came across the DIY and was wondering if there were any downsides to this mod?
I like it because 1) as stated, crude doesn't build up on the static blade as it does in the stock position and 2) the blade is more efficient pushing water and dirt down off the rear window versus across it!
I plan to give it a try when I get a chance, but thanks for the great instructions!
Cheers! M2
Old 01-18-2011, 11:48 AM   #14
sex
sex's Avatar
Drives: 09 5DR
It's been more than a year now and my only observations are:
1. The blade conformed to the glass .. doesn't affect function
2. It's hardly noticeable, especially if the rear headrest is up
Old 01-18-2011, 01:11 PM   #15
MadMax
MadMax's Avatar
So no issues with the blade staying against the glass while driving, i.e. the wind causing it to "chatter" at high speeds or anything....
Honestly, I am surprised that more people don't do this mod. Given the limited rainfall we get here in southcentral Texas, and the vast amounts of dust we have to put up with; this seems like a more practical set-up than stock.
Cheers! M2
Old 01-18-2011, 08:37 PM   #16
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
I got the idea from looking at Vitz in Japan.
It won't chatter at all, MadMax.
Also, gives confusion to people as to why the arm is stuck at that position (whereas we know, its still functional).
i wish i waited and followed this DIY. I'll forward this to another member who i tried to help, but couldnt get the wiper to set in at that angle...
Old 01-19-2011, 06:25 PM   #17
Midnight Drifter
Going Retro
Drives: '09 Tacoma | '90 Tercel
Snow/ice won't pile up on the wiper like that. I like the idea. Now, could you show us how to use a regular/replaceable auto parts store blade instead of that proprietary piece of junk? <.<
Midnight Drifter is offline   Reply With Quote
Old 01-24-2011, 01:57 PM   #18
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Remember to wear workgloves, the sheet metal there is crazy sharp, kioshi knows firsthand doing this mod. I wore leather gloves while working on it.
Only downside I think is to trying to clean the window with the washer fluid, gotta time spray. Doesn't bother me too much
Check out my Build thread:
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
Removing rear wiper fred812 Cosmetic Modifications (Exterior/Interior) 34 01-27-2013 12:22 AM
How-To: Liftback Rear Wiper Arm - Full Pivot! Chris07LB DIY / Maintenance / Service 5 07-24-2009 03:08 PM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 10:30 AM
Rear wiper function, is this normal? Yaris Dick General Yaris / Vitz Discussion 7 11-08-2006 09:46 AM
