Old 04-01-2010, 09:32 PM   #1
H3LlIoN
Drives: '09 Yarrrr hatch
Arrow 1ZZ TB/Inj/Rail/Coils
I have a complete setup off of a 1ZZ engine, includes throttle body, injectors, fuel rail and coils off of an 03 or 04 Corolla. Everything in working order, car had roughly 75K miles on engine when parts were pulled. These were not sitting out in a junkyard for months in the weather...parts came direct from dealership. I know TB will work on 1nz, AFAIK the rest will as well. Asking $200 shipped, cont USA
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline
Old 04-01-2010, 10:42 PM   #2
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
You may want to note that the TB you have pictured is NOT compatible with our cars as it's not a DBW throttle body.
Gideon is offline
Old 04-01-2010, 11:03 PM   #3
H3LlIoN
didn't know that. Will see if I can get the right one.
Toyota
Moving Forward
H3LlIoN is offline
Old 04-02-2010, 10:17 PM   #4
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
make sure the one you get is the one with the magic part number. There are 2.
search for 1zz TB chip swap threads
AlexNet0 is offline
Old 04-03-2010, 02:36 PM   #5
H3LlIoN
kthx for the heads up
Toyota
Moving Forward
H3LlIoN is offline
Old 04-18-2010, 08:38 PM   #6
Yariz
Drives: Yaris 3dr Hatchback
Will running this cause an issue a CEL? I have a 1ZZ TB now with no CEL. I have been debating upgrading to the 1ZZ Injectors but I am not sure its worth it.
Yariz is offline
Old 04-19-2010, 02:56 PM   #7
Gideon
★weeaboo★
Gideon's Avatar
^ I've had my 1ZZ TB and injectors on for awhile now, no CEL. I do have a 1/8th" TB spacer installed as well though.
Gideon is offline
Old 04-19-2010, 02:58 PM   #8
Yariz
Where did you get spacer? I haven't seen a need for it yet. Do you have to change anything other than the injectors? Rail? Also, did you see an improvement?
Yariz is offline
Old 04-19-2010, 03:08 PM   #9
Gideon
★weeaboo★
Gideon's Avatar
It came from another YW member who had it custom made. The injectors were added as a result of a CEL which was a lean code, he said after he installed the injectors the code went away.
I installed both TB spacer and injectors at the same time so I can confirm nor deny if there was ever such a condition or if larger injectors solve it.
You don't have to change the rail, stock one works fine. Might want to pick up new injector seals depending on the condition of the ones that are on there currently. Less than $10 for all four, so it's worth it to be safe.
No dyno so no real numbers. Since I installed both a TB spacer and the injectors I can't honestly say which was responsible but it does feel like it pulls harder at WOT.
Gas mileage has not decreased, however at cold start you can smell the difference because of how rich it'll run when warming up.
Gideon is offline
Old 04-19-2010, 05:33 PM   #10
cruz-gsr
cruz-gsr's Avatar
Drives: 08 Yaris Lift Back
i had the spacers made. its a 1nz on one side and 1zz on the other side. i will have another group buy soon.
cruz-gsr is offline
Old 04-19-2010, 05:38 PM   #11
Yariz
Why do I need that? My TB is working fine as is...
Yariz is offline
Old 04-19-2010, 03:35 PM   #12
Yariz
ok, sounds good. Where did you get the injectors? Do they usually run pretty expensive?
Yariz is offline
Old 04-19-2010, 05:39 PM   #13
Gideon
★weeaboo★
Gideon's Avatar
Same YW member who had the spacer made, it was around $60 for the injectors, I don't know how much they are from the dealer. Sorry.
No, this spacer did not come from you. Mike (mikenacarato) had this spacer made prior to your's.
Gideon is offline
Old 04-19-2010, 05:43 PM   #14
Yariz
Why do I need to get a spacer? Mine fits fine, and doesn't have a CEL.
Yariz is offline
Old 04-19-2010, 05:51 PM   #15
cruz-gsr
cruz-gsr's Avatar
to improve the air flow going to the manifold.
cruz-gsr is offline
Old 04-19-2010, 05:54 PM   #16
Yariz
Kewl well let me know if you guys decide to get an order together.
Yariz is offline
Old 04-19-2010, 07:08 PM   #17
captaincrunch
Chris
captaincrunch's Avatar
07 yaris s is that 1zz too?
captaincrunch is offline
Old 04-19-2010, 08:16 PM   #18
cruz-gsr
cruz-gsr's Avatar
no, the s has the same engine as a regular yaris 1nz
cruz-gsr is offline
1zz injectors suit the S/C just fine LtNoogie Forced Induction Forum 51 04-30-2016 10:11 AM
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
1ZZ TB and AM Intake gwasabi Performance Modifications 5 04-06-2009 07:36 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
