![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Cheaper, but still decent quality speakers?
Can anyone recommend some cheaper, but still decent quality speakers to replace the stock ones?
I'll be running them off of my JVC receiver's internal amp. (no external amp. will be used) just like the stock speakers now. I'd also prefer a set that has decent bass. I have a 10" sub. in the back and would like a little bass from the speakers too. |
this is a relative question. Cheaper compared to what? Infinity's are always nice, and relatively inexpensive...
Toyota Moving Forward ...even when you don't want it to. Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
Under $100 would be great.
Infinity speakers always sounded kind of tinny and metallic to me and the ones I've tried lacked any mids or lows. Those were Kappas though. |
#4 | |
IsLNdbOi
I know that. I just want some speakers that have more low end and mids than the stock speakers.
i have some pioneer $120 au for a set they are nice
Ok. Model number?
Are you running them on a separate amplifier or directly from the head unit? You can't make a recommendation unless you've tried it the way I've described I'll be running it. |
i will run to the garage
they are pioneer Ts-A1682s 16cm 280w max.
you know how to mount them in the old speaker you just rip out the guts of the stock speaker and screw the new into the stock plastic |
HIfonics components, they run around 50 bucks on amazon. I have a set of them in my install section.
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
yeh sorry mate got all excited about the Ok. Model number part
25 watts is 25 watts, that's probably the most the Headunit will put out. The components can run on wattages between 2-100 watts.
#14 |
![]() ![]() ![]() Drives: 2010 Meteorite Metallic LB Join Date: Feb 2010
Alpine Type S speakers are good for the money. $100 retail so online will be a bit less.
#15 |
Thanks for the suggestion S7V7N.
The AVX77's manual says it does 20W x 4 channels. Should I find speakers that do only up to 20W RMS? |
#16 |
The only ones that i seen that were fairly decent were some Blaupunkts Rated at like 35 watts rms, for the price that is. I think the factory speakers are rated at like 10 watts rms. Dude i would just get what fits your taste and eventually save up for a nice 4 Channel amp, matter of fact you could probably get some speakers and an amp that does maybe 50 x 4 for around 120 bucks. Everybody has there own personal preference, Name brand or no name brand, Anything will sound better than them paper speakers that are in there now. I know how it is to be on a budget, Pioneer has some decent budget speakers as well as Sony. Check the Sunday paper, Best buy usually runs speaker specials.
#17 |
Audio Junky
Infinity refrence 6.5 components... can find them online for cheap... around $100 for a pair. Regardless of what you go with, make sure you buy a pair of components & spend more than $80 online, or $150 in store. Stay away from co-axials/tri-axial/quad-axials... you only need 1 tweet per speaker, having 5 doesn't help sound quality.... if anything it makes things worse, but it does look good for the marketing department, and allows a company to charge more.
#18 |
Audio Junky
there is one person on this forum that swears up and down the deck does something like 17x4 rms.... I'd bet its much closer to 10x4 (at any acceptable amount of distortion). Most aftermarket decks are lucky if they can put out 17x4.... I doubt an OEM will be as good, or better than the aftermarket decks... but maybe. Regardless, its best to just save $150 and buy a small 2 channel amp to power your front 2 speakers, and the wires/cables needed to install the amp. It'll sound louder, and you'll notice more bass.
| Yaris sedan low and high beam | jorizk | DIY / Maintenance / Service | 10 | 03-02-2010 09:49 AM |
| Needed high quality speaker adaptors for 6.5 and 6x9 for sedan | YarisSedan | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 09-27-2009 02:43 PM |
| High quality coilovers avaialble for Yaris? | echosqwat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 09-09-2009 06:27 PM |
| Change to high quality filter lead to drastic drop in fuel efficiency | lh59 | DIY / Maintenance / Service | 19 | 07-02-2009 02:22 PM |
| What do you guys think of this high quality hubcap | YarisSedan | Cosmetic Modifications (Exterior/Interior) | 18 | 01-15-2009 04:34 PM |
