Old 09-25-2009, 02:21 AM   #1
YarisSedan
Drives: 08 Yaris Sedan
Needed high quality speaker adaptors for 6.5 and 6x9 for sedan
So my front speaker adapters are some cheap ones i got for free off crutchfield that tend to rattle when the mids are high. Also the rears i got the adaptors off ebay and they didnt seem to fit 100 percent perfect and they are also not completely solid they are made of some sort of plastic. So they actually curve a bit aroudn the speaker ot make them fit. Result is rear deck rattle again when there are any hard mids.
What iw ould like to do is get something more solid like wood for the rear and then put a ring of dynomat around it. And a more solid adapter for the front a well that wont be as flimsy and rattle too. And maybe a little bit of dynomat there as well.
Old 09-25-2009, 03:35 AM   #2
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I think you've got your answer right there...
A handmade birch adaptor plate with dynamat used as a decoupler. Personally I'd use 1/8" foam as well. That's me though...I usually overkill the deadening.
Personally, this is what I'd do. I'd make my own. You only need a jigsaw and a drill....maybe some sandpaper to make things nice.
― Thomas Paine
Old 09-25-2009, 11:07 AM   #3
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
A lot of the adapters you see for sale are made of MDF.... MDF screw holes strip easily, so I suggest using T-nuts or hurricane nuts & hex head machine screws. Hurricane nuts will sink into MDF well (though you have to use a lot of force), however T-nuts work a lot better in Baltic Birch or some other type of High quality plywood. T-nuts tend to bend easily in MDF.
Also... go with 3/4" thick wood over 1/2" if you can... thicker wood will mean less chances of flexing/rattling.
Old 09-25-2009, 12:29 PM   #4
YarisSedan
Yeah but im hoping someone would know a place that makes and sells them so i dont have to buy the tools to build my own =) I guess no choice then.
Old 09-25-2009, 01:15 PM   #5
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
You'd pay a prety penny in labor for a custom-fit adapter. If that's not a problem, PM your sepaker brand/model and I'll make you some to whatver spec you want.
Old 09-25-2009, 04:32 PM   #6
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
you can buy them on e-bay last time I looked... just gotta make sure you get the 6.5" version and not the 5.25 version.
There is also a PDF file somewhere on yaris world that you can print off, and it'll make a perfect cutout of the piece you need, just have to cut it out... throw it on a good piece of wood, trace, and pick up the jigsaw.
You'll also need a drill with a fat drill bit (3/8ths or 1/2") to start cutting the circular cutout of the speaker with a jigsaw. I'm looking to do this pretty soon too... cept i'll be doing it with both 6.5's and 8's. Time for me to buy/borrow a jigsaw. That or drive the 470miles home to have access to all the tools i'll need.
Old 09-26-2009, 01:55 AM   #7
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Honestly...
It shouldn't be THAT expensive at all to have an installer make a baffle for you. All you need to do is to come into the shop with the panel off and the door ready to be worked. Also, before you come in with the vehicle, scout the shops. Set one of them up to be ready for you to come in.
Personally, I'd befriend a specific installer. This way you can go to a certain person whether it is on work time or personal time. You can also follow the installer that you trust versus being chained to a certain store.
There are big benefits to doing this. My personal experience is a prime example of this method. I've known a certain installer for over ten years now. I've followed him from shop to shop until finally he opened up his own shop.
Well, guess what happens now? He and his co-owner give me almost free reign of the shop. I do my own installs as well as help them with some of theirs. It's a very fair symbiotic relationship for the most part. I bring the shop beer and food...and I get expertise to add onto my own experience, shop space, and free tool use.
― Thomas Paine
Old 09-27-2009, 02:43 PM   #8
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
hehe.... I'd like to use your tool for free.
yeah.... i once had an installer friend like that....that I lived close to.... for the most part however, just knowing people with the same hobbies (Home Theater & Car audio) will be of great service cause if you have say 5 friends who've all got a few years experience in sound..... you're bound to be able to have access to someones' shop and tools... I had three friends who either had a cool shop, or some cool tools.
Moving blows, all my tools, saw/router & jig, drill, jigsaw, EVERYTHING is 500miles away at my grandparents place for storage. The only thing I really have with me is a socket set, some wire strippers/cutters, and a drimel.... speaking of which, I got a speaker motor to disassemble...
Here are a list of some helpful things in a shop
Accurate table saw
Cordless drill, the higher the voltage the better
Lots of table top area to work on
Plunge Router with Circle jig
Air Compressor and nail gun
lots of clamps
And SHIT TONS OF LIGHTING.
the bare essentials however would be
Jig saw, a nice straight edge (carpenters style), and a cordless drill
