Old 10-29-2008, 08:56 PM   #1
IsLNdbOi
IsLNdbOi's Avatar
LEDs to replace interior lights: Which ones?
Ok, so I'd like to replace these lights with white LEDs:
- The ones up front above the rear view mirror (you push them to turn them on).
- The ones in the center of the roof that you can set off, on or on w/ the door.
- Thinking about replacing the LEDs in the three console knobs as well (AC recycle air / fresh air, AC temp., AC strength), but not sure how it would look with the all amber lighting Toyota has put in these '09 LBs.
- The light in the trunk / hatch area (driver side I think).
- The parking lights in the headlight housing.
- The rear license plate light.
I'd like to order from HiLEDs again: http://www.hileds.com/products.php
Which bulbs and sizes do I need from them to replace all of the above lights I've listed?
Are there better (quality / price wise) LEDs / companies than HiLEDs?
Also, my dealer drilled license plate holes into my front bumper even though I told them not to. They've offered to fill the holes and repaint the bumper, but lately I've been toying with the idea of putting white LEDs into those license plate holes and tying them into the parking lights.
To make it easy for everyone who might find this post useful, just quote this post and add the link to the specific bulb and list bulb's size and quantity needed next to each "-" under the corresponding light I've listed above. Thanks everyone!
Old 10-29-2008, 09:07 PM   #2
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
try optauto.com they sell some for the front in a set and try oznium.com they sell some for the center try superbrightleds.com for the rest
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-29-2008, 09:39 PM   #3
Meteorite_Marty
I replaced all those lights you mentioned with white LEDs. The white color I use is a 6500K, which is a cool, bright white, with a very slight hint of purple. Also called Super White or Hyper White. No trace of blue.
To do the console control knobs I ordered 3x Super White Neo Wedge Based LED Bulbs (30% brighter) from www.autolumination.com Make sure you get Type B.
http://autolumination.com/74.htm
For my gear shifter I ordered 1x Tri-Power 3 LED Bulb from www.autolumination.com
For the map lights (next to the rear view mirror), I used a 194 replacement bulb from www.vleds.com. I ordered 2x V-LEDS HID WHITE 11 SMT LIGHT BULBS. These will also work for the parking lights and license plate (which I will order later, because I wanted to test the fit and color before I ordered more).
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
I replaced the 31mm festoon bulb for the cabin light (middle of roof with the switch for ON/OFF/DOOR) with a V-LEDS HID WHITE 48 M-SMT PCB light board.
For the trunk light, I replaced the 36mm festoon bulb with a V-LEDS HID WHITE 30 M-SMT BULBS light board.
I cannot begin to tell you how great the bulbs are from VLEDS!!! The customer service is good. The quality of their bulbs is amazing, price is affordable, and output is so bright. Most importantly, each of the VLED bulbs are the exact same color, so your interior will match perfectly. The accessories for the VLED blulbs (the wiring and festoon blanks) are all interchangeable.
I will take pictures of my interior lighting modifications.
Old 10-29-2008, 09:46 PM   #4
Meteorite_Marty
I also soldered LEDs into the driver side door window switch, and the center door lock switch near the parking brake. I forgot which LED bulbs I used for those (I can check into that if you are interested).
No more GREEN for me!!!
Old 10-29-2008, 09:47 PM   #5
Meteorite_Marty
Rear is a 36mm festoon. I crammed a 42mm festoon in there, and it holds my 30LED light board in there perfectly.
Old 10-29-2008, 10:04 PM   #6
IsLNdbOi
IsLNdbOi's Avatar
This is a 42mm festoon LED bulb, right?
Old 10-29-2008, 10:56 PM   #7
Meteorite_Marty
No, that festoon-dummy is a 31mm. If you went with the 48 LED for your cabin too, that kit comes with a 31mm and a 42mm, which you could then mix and match interchangeably.
Old 10-30-2008, 01:08 PM   #8
FunctionSpec
Super Newbie
FunctionSpec's Avatar
Drives: 2007 Yaris Liftback White
WOW you were able to get a 48 M-SMT LED board in the dome light area?? Man I should of went with that instead. Thought it was going to be too big so went with a 30 M-SMT instead. But I guess I can put that in my hatch area and get a 48 M-SMT for the dome
Can't image how bright the 48 M-SMT is because the 30 M-SMT is already super BRIGHT!
I can vouch for VLEDs as well. I also have the 11 SMT 194 bulb for the parking, map and license plate lights and they are really bright. Excellent quality and affordable price.
JUST DON'T GET THEIR CHEAPER LED LIGHTS, THEY SUCK. Had to replace all my cheaper LEDs because the light output on them was pretty dim. Pay the money to get the SMT bulbs. They are worth every penny!
FunctionSpec is offline   Reply With Quote
Old 10-29-2008, 10:55 PM   #9
sportin83
Drives: 2008 blazing blue yaris LB
i used a 31mm bulb for the front lights and 39mm for the hatch light . they r a little longer than the factory bulb but worked fine. and all the domelights are a standard 194 sizei bought all mine off ebay.http://stores.ebay.com/warden-jp2002
http://cardomain.com/ride/3151056
mods: custom sub box, i hit 141.4 db, new speakers, double-din nav, foglights, cruise, CAI, strut brace, under car braces, short antenna, remote start, alarm, actuators in doors and hatch
coming soon: window tint, custom sub grills, tach and........
sportin83 is offline   Reply With Quote
Old 10-29-2008, 10:58 PM   #10
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
PICS PICS PICS to see how it looks
Its a Chao!!!
Old 10-30-2008, 09:53 AM   #11
IsLNdbOi
IsLNdbOi's Avatar
Marty, just to make sure everything is correct I'd get these for the map lights (the ones next to the rear view mirror that you push to turn on or off), the parking lights that are in the headlight housing, and the license plate light for total 5 bulbs (3 sets):
http://www.v-leds.com/Shop/Control/P.../vpid/4835704/
Then I get one of these for the cabin light (the one with the switch for on / off / door):
http://www.v-leds.com/Shop/Control/P.../vpid/5217649/
Finally, one of these for the trunk / interior hatch area:
http://www.v-leds.com/Shop/Control/P.../vpid/5168718/
OR these
Did I get all of that right?
Originally Posted by ROCKLAND TOYOTA View Post
do you want someone to come there and do the install as well......
Sure. I'll wait for you to come over so you can install them for me.
By the way, were you able to find out if there is a new part number / new version of the TYC tail lights for the 5-door LBs? Also, will the mudguards for the '07 / '08 LBs fit the 5-door LBs?
You do work at a Toyota dealer right?
Old 10-30-2008, 08:44 PM   #12
IsLNdbOi
IsLNdbOi's Avatar
Thanks for all the input guys. I've ordered the 48-LED light for both the cabin light and the interior trunk / hatch light. I'm going to see if I can shove one of these 48-LED boards into that hatch light area.
Still looking for bright, white LEDs that will fit into standard license plate holes in the front bumper. I need to find some that are water-proof.
Old 10-30-2008, 08:45 PM   #13
custom Lftback
custom Lftback's Avatar
Sweet deal!
Old 10-30-2008, 10:50 PM   #14
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
All you need is 2 x T10 with the LED's of your choice as the number plate light
is weather proof .
I am already running 2 T10's with 4 Flux LED's on each. works and looks great,
Old 10-30-2008, 11:28 PM   #15
IsLNdbOi
IsLNdbOi's Avatar
is weather proof .
I'm not talking about the light for the rear plate in that post. My dealer drlled holes for the front plates even though I told them not to. Now I have two holes on my front bumper. The holes are thr standard size for license plate screws here in the US. I want to put a white LED in each hole and wire them to the paking lights.
Old 10-31-2008, 05:30 AM   #16
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
there are some t10 water proof ones around , i will take a photo for you if you like. have about 4 prs sitting in the workshop
Old 10-31-2008, 08:25 AM   #17
IsLNdbOi
IsLNdbOi's Avatar
So T10 sized LEDs are the same size as standard license plate mounting holes in the US?
Old 10-31-2008, 07:51 PM   #18
battleversiontc
arent the holes like a 1/4 inch or so
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
How do you replace the factory fog light bulb DjT DIY / Maintenance / Service 6 10-25-2008 07:24 AM
GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... riceboy Items for Sale by private party 453 07-14-2007 08:30 AM
Cheap LEDs Interior and Exterior jamal1984 Cosmetic Modifications (Exterior/Interior) 10 04-11-2007 11:08 AM
Yaris S Replace Fog Light Bulbs jamal1984 DIY / Maintenance / Service 1 01-13-2007 08:16 PM
