Old 10-24-2008, 12:08 AM   #1
DjT
Drives: 2007 5DR Yaris HB RS
How do you replace the factory fog light bulb
I've been seeing a bunch of aftermarket fog light installation DIY - although I can't find any simple replacement instructions.
I did a search and I can't find anything.
I looked in the manual, and apparently Toyota thinks we're too incompetent to do it ourselves and is telling me to bring it into the dealership to replace the bulb.
uhhh.
Ya. Thanks mmkbye
DjT is offline   Reply With Quote
Old 10-24-2008, 12:48 AM   #2
DjT
Cool.. Thanks for the help! lol... I looked through the repair manual - approx page 120 in the lighting section. Not as bad as I thought.
Old 10-24-2008, 03:08 AM   #3
AznGouki
Metsu
Drives: NCP91 ; E36
So you figured it out? Best way I noticed is to take the bumper off. But just doing that is pretty retarded. Way too many useless screws and clip things
AznGouki is offline   Reply With Quote
Old 10-24-2008, 04:57 PM   #4
DjT
Ya, that's pretty ridiculous lol... What I did actually is I took the 3 screws off, and just bent the cover outwards as opposed to actually taking the whole wheel well off, which is also a very far fetched idea from Toyota. Just gotta be careful not to break it, but I did it on both sides and I got my new yellow bulbs installed! I also did the DRL / Independent Fog Light mod which was a breeze to do. Now I can finally use my fog lights as DRL.
Old 10-24-2008, 05:04 PM   #5
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
if your able to jack up front abit just take off splash shields and your golden. i just changed my connectors to ceramic.....
Old 10-25-2008, 01:21 AM   #6
DjT
I'm still figuring out a way to disable the little "Christmas light" looking bulb next to the big bulb in the light case. I'm not sure if you guys know what I'm talking about. There's a little tiny light on the inside of the case, not the main bulb, it's in the inner part. How do I disable those lights all together, without having to actually remove the bulb?
Old 10-25-2008, 07:24 AM   #7
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
to replace the fog bulb just go behind the wheel wells.. push the plastic and pull it back you should see the fog bulb and viola!!!! itll take you 2 minutes on each side..
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
The right fog light bulb exploded and cracked the lense vacantj DIY / Maintenance / Service 1 08-01-2007 04:07 AM
Bulb Size For After Market Fog Light Kit razzorjet2 DIY / Maintenance / Service 1 04-10-2007 02:15 PM
Yaris S Replace Fog Light Bulbs jamal1984 DIY / Maintenance / Service 1 01-13-2007 08:16 PM
