Old 02-20-2010, 11:32 PM   #1
bankrobber
Drives: 2007 Yaris Hatchback
Removing drum from rear axle
What is the best way? I wanted to check my rear brakes but the drum is on pretty tight. I tried hitting it a few times but it didnt come off. Not much space between the dust cover and drum to hit. I never did drum brakes before. On my old truck I always replaced the disc brakes and paid to have rear drum done by mechanic. Only way I know is to hit it with a hammer. Just wanted to check before I did that. I have 82,000 highway miles. When I hit it a bunch of brake dust came out!!!!
bankrobber is offline   Reply With Quote
Old 02-20-2010, 11:44 PM   #2
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Make sure your brake isn't set. I know that sounds dickish, but you'd be surprised .
If a rubber mallet doesn't do it, you can thread some bolts into the holes on the face of the drum and press it off. Also, I've heard that cheap steering wheel pullers are a good fit.
If you're using a hammer, tap it, don't smack it hard and risk bending something.
Old 02-21-2010, 12:06 AM   #3
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Never hit a drum. I was taught that a long time ago; you just bend or crack something. I take a punch, line it up between the studs, and smack it a good one, repeat between the other studs. Nearly every time, the drum will just pop off. If that doesn't do it, apply can be GENTLY applied, and the punch routine repeated.
Old 02-21-2010, 12:09 AM   #4
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
Since your car has so many miles, you may run into one other problem. The shoes may have worn the drum enough so that there is now a ridge inside the drum that will prevent the drum from coming off directly. In this case, you will need to remove the rubber plug from the backing plate and use a slotted screwdriver to manually adjust the brake shoes back away from the drum before you try the next step.
Those drums fit pretty tight and get frozen with rust, so don't bother with the hammer. You would probably beat the daylights out of it, and it still won't come off (I've tried). Find the proper METRIC size bolts to use in the two threaded holes on the face of the drum near the axle. Clean the holes first, then screw in the bolts until they stop. Then turn each bolt alternately a half-turn at a time to press off the drum. If that fails (if you strip out the threads), then you'll need to use a puller.
Maybe someone here can advise on the proper size bolt. I just had my drums off last month, but didn't make note of the size bolt that I used.
Reddog99 is offline   Reply With Quote
Old 02-21-2010, 12:40 AM   #5
bankrobber
I tried a screwdriver between backing plate but just it barely moved. If I keep doing that the plate will bend. I thought the rear brakes last longer than front?
My front disc is still 50% good. I may have to try the two bolts you mentioned. I dont have any grinding sound from brakes but I got a nail in my tire so after I took it off to put a plug in I decided to check the brakes. If I bend the lip to the backing plate can I just hit it back tight to the drum??
Old 02-22-2010, 12:57 PM   #6
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
The object is to adjust the brake shoes away from the drum by turning the star wheel adjuster. If you're bending the backing plate, then you are doing something wrong. After you adjust the shoes away from the drum, then you need to use the two bolt method. If your drums fit as tight as mine did, then they won't come off just by beating or hand pulling. Be wary of using a puller: it must have METRIC threads for the brake drum holes.
Old 02-21-2010, 01:59 AM   #7
bankrobber
I wonder if Auto Zone has one in there free loan a tool program
Old 02-22-2010, 01:25 PM   #8
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
you are supposed to insert long metric bolts into the holes on the drum, and drive the bolts
in evenly. they will bottom out, and then act as a press, and push the drum off.
if the brakes are worn and the adjuster has them compensated too far, the pads may
make drum removal difficult, but it will be loose and you'll know to reach in the back and crank the
adjuster down so you can get the drum off
127.0.0.1 is offline   Reply With Quote
Old 02-22-2010, 04:06 PM   #9
markitect
Drives: Yaris
Heating up the drum works well too. You can do several hard stops then immediately take the wheel and drums off, or I've used a blow torch on a low heat setting, any propane torch should be fine too.
They key is you don't want a focused hot flame, you just want to slowly and evenly heat up the drum. Go little by little and don't forget to use welding gloves, or oven-mitts to pull it off.
And before people start complaining about heat damaging it, keep in mind how hot brakes get. And I take no responsibility if you touch something while it's still hot an burn yourself.
markitect is offline   Reply With Quote
Old 02-22-2010, 04:11 PM   #10
ozmdd
ozmdd's Avatar
The metric bolts should pop it right off. I suggest the cheap puller simply because it has a selection of metric and standard threads in it. I think they do loan these.
If you search the thread for the DIY penguin garage spacers install, there is a mention of the correct metric thread size somewhere in there, IIRC.
Old 02-22-2010, 05:49 PM   #11
YarisSedan
Drives: 08 Yaris Sedan
You dont need any sort of puller whatsoever. All you need to do is find 2 bolts that match the holes. Tighten them down with a rachet even amounts and the drum will pop off. Smacking it with a rubber mallet a few times usually losen things up but if that dosnt work then the 2 bolts is the way to go. You can also spray a bit of WD-40 on a hub as there is probally some accumilated rust when you try to remove it to help ease things up.
Try that before any thing else. If its comming off hard as your tightening the bolts. Every few turns smack it again with the hammer and turn the bolts a few more. This will help break loose the shoes if they are seized onto the drum.
Otherwise you will snap the pins and the shoes will come apart when you remove the drum. Unless you plan to do rear brakes then just order a hardware kit and go to down on the bolts until the drum pops off.
Old 02-22-2010, 05:57 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
M8X1.25
or as most people call them "10mm bolts"
~PenguinGarage has spoken~
Old 02-22-2010, 07:42 PM   #13
YAR1S
YAR1S's Avatar
M8X1.0
you beat me to it
-Jen <3
Old 02-23-2010, 02:35 AM   #14
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
you beat me to it
+1 on the bolt solution.
Old 02-23-2010, 08:51 AM   #15
1stToyota
1stToyota's Avatar
The Yaris drum is different then, if it's M8x1.0
All I've ever seen so far is 8mm x 1.25
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 02-23-2010, 10:12 AM   #16
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Yes, I believe that they are course thread NOT 1.0 pitch.
DerFlosser is offline   Reply With Quote
Old 02-22-2010, 09:03 PM   #17
DerFlosser
DerFlosser's Avatar
Drives: Yaris
I used the steering wheel puller I purchased to remove the steering wheel. Worked like a charm...purchased it at NAPA for around $18. It comes with assorted bolts...as set of which worked perfectly for the drums (8mm).
Old 02-22-2010, 10:12 PM   #18
auxmike
auxmike's Avatar
I had a box of hardware I took off a Saturn destined for the boneyard and found two bolts that fit perfectly.
It works like a charm!
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Removing rear wiper fred812 Cosmetic Modifications (Exterior/Interior) 34 01-27-2013 12:22 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
HELP - Removing rear hub! Doc Zaius DIY / Maintenance / Service 16 05-13-2009 02:52 PM
