Old 04-21-2009, 08:00 PM   #1
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Ultra Racing 23mm Rear Stabilizer Bar
Installed one of these bad boys this evening. Big thanks to Garm at Micro Image for sourcing these for us and offering them at a reasonable price! Nice part, but I'd recommend not trying to install it by sliding under the car with a couple wrenches between runs at an autocross when you're working from the middle and can't really see either end. I tried that Saturday, didn't work.
I'm feeling a little scatterbrained and disorganized this week, so this review will follow suit. Bear with me.
First, there has been some confusion about whether the TRD rear bar is 19mm or 22mm. I've seen a few references here on the forum that hint at it being 22mm, so I want to clearly state for the record that the TRD rear bar is 19mm. Might be 22mm for some other Toyota, but not for the Yaris. 19mm, I just measured it, trust me.
Now, myself and others have told tales of installing the TRD bar by just sliding under the car and bolting it on. No muss, no fuss, no jacking up the car, no taking off the wheels, just bolt it on. And that's a fact. But, I've learned something... if you have wider wheels (especially with proper offset), it's a little tight getting that TRD bar in and out. I was still able to do it with my 15x7 41mm offset wheels, but it wasn't as easy as it was with stock wheels.
The new 23mm bar, was even tighter of a fit between the wheels, which is partly why I couldn't fit it Saturday with the car on the ground. The other reason I couldn't get it installed Saturday was that I thought it was made wrong somehow because it didn't seem to fit. Here's the deal: The TRD bars are made a bit loose. That is, the ends are a little bit wider than the points they mount to on the car. Makes for a really easy slip fit. The 23mm bar is a much tighter fit, in fact, it LOOKS like it won't fit at all (especially when compared side-by-side with the TRD bar that is made wider), but if you hook one end and push the other end outward, sure enough it will fit!
So, I put the car up on stands today and went back to it. Ended up removing one wheel just to make it easier. Once stretched into place, bolting the bar on is a snap. I reused the bolts that I already had on the car from the TRD installation.
Initial driving impression: After setting the rear shocks to near full soft, I went for a drive and found that I had most of the steering response and front grip that I had with the rear shocks set almost full stiff at the autocross Saturday... but without the "feel every crack in the pavement" harshness that comes with having the shocks set that stiff. Nice. That's just what I was after.
I'll have to live with it for a while and get some autocross time with it to have a better idea of how well it works, but it seems like a step in the right direction for me and anyone else who is interested in less understeer and is confident in their ability to handle oversteer should it occur.
BTW, I now have a TRD bar (just like this one) for sale, PM me if you're interested. This bar comes with a few scratches, some dirt, a racing pedigree, and no bolts.
Here's a couple crappy photos for your viewing pleasure. You can see that this bar doesn't fit into the slot in the beam axle like the TRD bar does. It hangs a bit lower, but no lower than the fuel tank or exhaust or anything else, so it doesn't matter. I think I need to paint it black.
Oooh, let's ramble a little bit more. This first photo allows you to visualize a little bit how the rear sway bar works (something that a lot of people just don't "get"). Look at the picture. Visualize making a right turn. Weight shifts to the left. In the rear, the beam axle should twist a bit allowing the right rear tire to stay in contact with the road in all but the most extreme turns. What does the swaybar do? It resists that twist, it makes that inside rear tire want to lift. But, if the inside rear tire is lifting... where is that weight going? It's got to go somewhere. The answer is that it transfers diagonally across the car to the opposite side front tire. THAT is what a rear swaybar does for you, it transfers weight to the outside front tire in a turn.
On a FWD car, it's the outside front tire that is being asked to do the most work and it's the one that causes understeer when it loses grip. Putting more weight on it at the time that it needs it most allows it to grip more. Good stuff. There is also a secondary effect, though. Some of that transferred weight also ends up on the INSIDE front tire (think about it, you've made the car a tripod at this point, both front tires are sharing more than their usual share of the weight), which reduces inside wheelspin if you're trying to accelerate out of the turn and actually allows you to do so. Cool, huh?
Old 04-21-2009, 09:16 PM   #2
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Nice ! I'll be buing one real soon if Garm still has any left...
Old 04-21-2009, 11:19 PM   #3
kngrsll
Apexing Egg!!
kngrsll's Avatar
awesome... i need to get around to getting one of these...
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 04-21-2009, 11:44 PM   #4
Lafiro
Drives: 06 Yaris Sedan
How about converting the rear to independant suspension?
Old 04-21-2009, 11:53 PM   #5
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Nice review thanks!
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 04-21-2009, 11:53 PM   #6
Loren
What?
Loren's Avatar
Um... Sure. Why don't you do that. Then you can write a new post about it and tell us how it worked for you.
Old 04-22-2009, 01:40 AM   #7
Loren,
Thanks for the straight-up review. I'm glad it's not "too much" -- I'll order a bunch more. Keep us posted as you continue to drive the car!
Old 04-22-2009, 01:46 AM   #8
Loren
What?
Loren's Avatar
No, not too much at all. Even with my stiffer rear springs, it doesn't seem like too much. I'll be able to comment further after I autocross with it, but I'm expecting good things.
Old 04-22-2009, 02:44 AM   #9
Ah, nice. I'll be installing one of these on my friend's LB once his order with Garm is paid and sent.
Old 04-22-2009, 04:45 AM   #10
ddongbap
Hella interested in seeing how this will modify handling.
Old 04-22-2009, 08:46 AM   #11
33OH
Drives: '08 Yaris
Aah!! Now I need one of these too! Damn you Garm!!
Old 04-22-2009, 09:35 AM   #12
xbalance
Drives: stock
how was the respond in the slow, mid, high speed when taking a corner? if continue push will it oversteer? compare to TRD bar respond?
xbalance is offline   Reply With Quote
Old 04-22-2009, 09:56 AM   #13
Loren
What?
Loren's Avatar
Like I said, I just put it on yesterday evening and I'll know more after I've lived with it for a while and after I've autocrossed with it. I'm not going to push it hard enough to find how it handles at the limit on the street.
I can answer the last parts of your query:
"if continue push will it oversteer?" No, of course not. No way, no how, that's not how FWD cars work. If it's understeering and you keep your foot all the way on the gas, it's going to keep understeering. You won't get oversteer unless you lift or brake in a turn. With a larger rear bar, lift-throttle oversteer should be greater, however.
"compare to TRD bar respond" It's a much stiffer bar, yes, it provides better steering response than the smaller TRD bar.
Old 04-22-2009, 02:11 PM   #14
jkuchta
Drives: 2007 Yaris hatch (red)
I also installed a 23mm bar at Garm's on Monday.
I haven't been able to push it yet, but the ride quality is the same, and turn-in is much quicker/more responsive, much as Loren has mentioned.
The car does not lean nearly as much as stock.
I'll continue to post as I continue to push this bar, but so far I think it's one of the better mods anyone can do!
jkuchta is offline   Reply With Quote
Old 04-22-2009, 02:19 PM   #15
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Having just installed the TRD bar this morning (and loving the result), it's nice to know that's not the biggest bar available.
I look forward to your post-autox thoughts!
Old 04-22-2009, 03:33 PM   #16
Loren
What?
Loren's Avatar
Drove to the bank a while ago. I'm starting to figure things out a little. I have a strange habit when I'm driving... I tend to do what I need to do to get the car to "feel" right without thinking much about it. (this is part of the reason I'm good at autocross, I can adapt to the car and what the car is doing without having to think about it) My tendency to make such adjustments sometimes makes it hard for me to evaluate changes like this one.
What I'm finding is that, just as one would expect, with the rear being stiffer, overall body roll is reduced. Now, since I'm not in "economy mode" while testing this (when I'm in economode, I'm more focused on just using a light throttle than what the car feels like), I find that I'm subconsciously accelerating harder out of turns to get the car to roll to where it feels like it "should"... where it used to before. As a result, I'm carrying considerably more speed around the typical turn than I was before without any drama.
So, in a nutshell, the bar seems to be doing exactly what it should do. Shifting more weight to the front, allowing for better front traction in a turn.
Could be my imagination, but the steering feels different. I want to say it has a little more "centered" feel to it. Like it wants to go straight, takes slightly more effort to turn. By the time I figure that one out, I'll be used to it!
Old 04-22-2009, 03:45 PM   #17
Driving AWAY from the bank, with the sack of money... THAT is the true test...
Old 04-22-2009, 04:26 PM   #18
YarisSedan
Drives: 08 Yaris Sedan
I am awaiting the day i turn on Cops and see a yaris police chase!
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
