![]() ![]() Drives: 07 Yaris Sedan Join Date: Jan 2009
Brief acceleration issue
I have a 2007 Toyota Yaris with 64000 miles.
Today when I was accelerating after sitting at a traffic light, I noticed my Yaris did not accelerate, rather it revved to about 4000/5000K RPM, and shuddered. Sequence of events: It was 95F outside when it occurred. 1. Spent 40 minutes driving 70mph on the highway. 2. Spent 5 minutes driving 35mph in the city. 3. Came to a red traffic light, braked, came to a stop to 45 seconds. 4. Placed my foot on the accelerator. 5. Car moved maybe 3-5ft, then engine started to rev to 4000/5000K RPM. 6. Car did not move, and shuddered. 7. I took my foot off the accelerator to let it go down to 0RPM, then tried again, and the car started to move. 8. I drove for maybe 1000 ft and it started again, however it was different than the first time. I pressed the accelerator, it revved a bit, and 5 seconds later it started to accelerate, but with a shudder. 9. I pulled off to a side street, let the car sit for 3-4 minutes. Continued driving and it was OK for the rest of the day. What happened and should I be concerned that my engine or transmission is f'd up? |
Half a Bubble Off Plumb
Automatic? Have you checked the transmission fluid level?
sounds to me like a transmission issue too...
![]() ![]() ![]() Drives: 07 Yaris Sedan, Auto Join Date: Jun 2010
accidently bumped it into neutral at the light?
![]() ![]() Drives: 2007 Ford Mustang GT Join Date: Dec 2008
Converter lockup?
> Haven't checked it yet. I will look at it. sounds to me like a transmission issue too... > I hope it's not. ![]() accidently bumped it into neutral at the light? > Nope, I don't believe I did. Converter lockup? > I will research more about this. I'll check the service manual. |
Beast
check if ur maf is plugged in correctly
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
check your floor mats! Also if you are over the age of 75, file a lawsuit!
MAF sensor is okay.
Transmission fluid is okay. I'm under 75, but my floor mat on the driver side is missing a hook. |
diaper change in a yaris
Drives: 2009 multimode hatchback 5dr Join Date: Dec 2009
i'm having the same issues as you are having in my mmt transmission. the car is sluggish and often doesn't accelerate properly.if i read correctly, you placed your foot on the gas,the car jerked and then you removed the foot from the gas pedal?
Reading several posts about this "sluggish" yaris stuff,i think the ECU got used to highway speeds,and when you needed to accelerate from a stop,your car jerked. try to continue the press on the gas.
"there is no secret to the balance..you just have to feel the waves.." Heretics of dune. |
#11 | |
About 100 ft later when there wasn't any cars around me, I pressed the gas to the floor and then immediately off, the car revved but didn't move until 3 seconds later. It was only until I came to a complete start and turned off the car, then turned it on, everything was back to normal. So maybe it was a computer issue. Further thoughts? By distance, I do 90% highway driving. By time, 50% highway. |
i still think it's not a transmission issue but rather a sluggish ecu.do you still have a warranty? if so, ask the dealership to connect to a scanner and log any errors.
| Toyota Recalls | auxmike | General Yaris / Vitz Discussion | 535 | 02-25-2021 07:13 PM |
| Water Pump issue, after taking in for Recall | GeneralDon7 | General Yaris / Vitz Discussion | 34 | 05-27-2012 09:04 PM |
| heater control box issue | DevilGirl | DIY / Maintenance / Service | 12 | 01-08-2010 04:45 PM |
| more acceleration with smaller tire diameter? | Stiv | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 02-28-2009 08:50 AM |
| CONSUMER REPORTS : MARCH issue reviews '09 YARIS . | gid | General Yaris / Vitz Discussion | 93 | 01-06-2009 05:10 AM |
