Old 02-27-2009, 10:49 AM   #1
Stiv
Drives: Yaris TS 1,8L
more acceleration with smaller tire diameter?
So, my (stupid?) idea is to replace stock 205/45 R17 with 225/40 R15.
Now, would this result in a better acceleration because of smaller tire diameter? I don't like to drive fast, just like to be the first after the green light :)
If this would mean just a small improvement in acceleration than I won't do it.
What would be the best (cheap?) way to improve acc? And no, I can't take the back seat out.
Thanks
Stiv is offline   Reply With Quote
Old 02-27-2009, 11:04 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
Thanks
best cheap way to improve acceleration is nitrous
and the car will FEEL faster, but you'll really be going slower on a much smaller tire diameter
Old 02-27-2009, 11:06 AM   #3
Morgan
Morgan's Avatar
Drives: 07 MM LB
you could try swapping in a scion transmission, they have shorter (~sportier) gearing :)
Old 02-27-2009, 11:15 AM   #4
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
turbo or just accelerate hard to 40mph then relax
Its a Chao!!!
Old 02-27-2009, 11:26 AM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
wtf, scion transmission? that won't work, scion transmissions don't fit on toyotas
btw OP is in a different country ;)
Old 02-27-2009, 11:29 AM   #6
Morgan
Morgan's Avatar
Drives: 07 MM LB
it would probably rub anyway...
(oh and LKQ does ship internationally)
Old 02-27-2009, 11:29 AM   #7
TheRealEnth
Beast
you can always throw in a GSXR1000 in the baby and call it a day.... dont know how long itll last.. ;D
Its a Chao!!!
Old 02-27-2009, 11:30 AM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
ohhhhh she did NOT just go there
Old 02-27-2009, 11:40 AM   #9
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
I went from 185/60/15 (23.7 in diameter) to 205/50/15 (23.1 in diameter) with MT the car feels much better as a sport car, speedo is off by 3-5mph (GPS) depending on speed. It does accelerates faster and breaks faster, feels like a sport car.
The down side is no more hiper mileage, used to get 40-45mpg now taking in mind the difference in tire diameters I'm only getting 36-39mpg (I guess it also has to do with the factor that the car feels sport and I'm enjoying it a lot).
For Highway driving it's OK for short periods of time, RPMs went up. But for back roads 5th gear rocks between 40 and 50 mph
If you don't mind the MPG this is the way to go and make your Yaris feel very SPORTY!
2cts
CLA 250, 4MATIC
Old 02-27-2009, 12:22 PM   #10
BrazdonW
What kind of car is that?
Drives: Yaris 3d liftback
i thought about doing this too
a little more stress on the engine is all you have to worry about if you don't mind your speed and odometer being off along with slightly higher reving on highways.
try to use lightweight wheels and any other lightening you can to relieve a little stress off the engine
Old 02-27-2009, 02:09 PM   #11
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
listen to this guy. i raced him and even with everything i'd done to my car, his light weight 15's spanked my heavy ass 18's.
but that was before i was boosted
Old 02-27-2009, 03:37 PM   #12
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Thanks
You have a 1.8TS your car already has a much shorter gearing ratio than the US Yaris.
I would not do such drastic change. My suggestion, just replace the OE 205/45/17 tires for some stickier 205/40/17.
Haven't you heard what the Yaris is all about? With out a serious amount of money a yaris will never be fast on a straight line. However, with some suspensions mods it will rule on a curvy road.
Have you checked the TS section here? We have some information there that might be of interest for you.
If you want to improve acceleration:
- Remove weight (Rear seat weights a ton!)
- Intake ( You can use an intake for the US scion xD) CaliYaris, a sponsor of this site has a nice option (AFE intake)
-Exhaust. You have to go custom. 2.25" pipe from the cat back with straight thru resonators.
- Under drive crank pulley. CaliYaris has one also.
You will be at 120-125whp after this with a car that weights just above 2,300lbs
You will feel an improvement on the acceleration.
Old 02-27-2009, 04:00 PM   #13
justjesus
justjesus's Avatar
Drives: 2008 Liftback
Lightweight weels make a nice diff. I went from stock 15" steelies on 185s, to Racing Harts that weigh about 9lbs and on 195/50-15s. Very noticeable difference on acceleration.
Old 02-27-2009, 06:39 PM   #14
BrazdonW
^^^ i believe that
you will even notice in 5th gear to amouth of pull you gain while cruising
Old 02-27-2009, 06:58 PM   #15
ddongbap
Or, you might go slower with too much Nos, as you may be burning more rubber.
Old 02-28-2009, 07:50 AM   #16
BrazdonW
just wait untill you get get some lightweight wheels along with that boost ;)
to both of our defenses though in that race, we both had girls with a little booty in our cars at the time lol
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 06:29 AM
Quick-Link index for Yaris tire searches on TireRack WolfWings Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 09-16-2007 12:48 AM
Tire Pressure Max deebrown DIY / Maintenance / Service 82 08-10-2007 09:44 AM
Tire diameter list grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 06-04-2007 04:03 AM
