Old 07-30-2010, 07:55 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
Running your speakers in series or parallel that is the question.
So both my subs are single voice coil 8 ohms
the12volt.com recomends this setup
However this is how i have it setup right now.
Old 07-30-2010, 07:58 PM   #2
YarisSedan
These are the specs on the amplifier
RMS Power (at 14.4V, 20Hz-20kHz)
Per channel into 4 ohms: 50W x 4 (1% THD)
Per channel into 2 ohms: 75W x 4
Brigded 4 ohms: 150W x 2
Specs on the subs
*Impedance: 8 ohms *Re: 6.5 ohms *Frequency range: 35-350 Hz *Fs: 35 Hz *SPL: 87 dB 2.83V/1m *
I bridged the rear channel but it looks like im running at 16 ohms?? So the top would be ideal?
If that is the case should i run a power wire directly off the amp and split it into two to run it directly to the positive and positive. And then off the negative side of the amp to negative negative.
Old 07-30-2010, 09:21 PM   #3
sleey0
Drives: 2008 Yaris LB
You just have to use a small strand of speaker wire and connect the positive terminals on the subs together. Do this for the neg.
Afterwards, tap a longer strand of speaker wire into each and attach to the amps corresponding + and - terminals.
That would work best as it would allow you to run a lower ohmage at 4.
sleey0 is offline   Reply With Quote
Old 07-31-2010, 02:06 PM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
top picture is parallel wiring, bottom is series.
Parallel = lower ohm load, by half (two 2ohm drivers = one 1ohm load)
Series = doubling the ohm load. (two 2ohm drivers = one 4ohm load)
if you do parallel the easiest way to wire is to run 2 sets of speaker wire into the amplifier terminals. One set for each sub.
Old 07-31-2010, 02:40 PM   #5
YarisSedan
I rewired it parallel. The subs actually hit very hard now. The kind that you can feel in your seat. Only downside is i can hear the speakers capping out. They start to make a popping sound when i turn the volume up. I adjusted the gain down a lot lower and now seems to be okay and matched with the front.
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
Need some experienced advice about speakers Nexus1155 In Car Entertainment + Electronics (audio / video / alarm) 0 06-28-2010 10:18 AM
Speakers for 2009 4DR LB AutoXBot In Car Entertainment + Electronics (audio / video / alarm) 5 05-02-2010 11:49 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
installing new speakers...bracket question luckydlb DIY / Maintenance / Service 3 03-16-2007 06:53 PM
