Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 02-16-2015, 05:55 AM   #1
basharalezze
Drives: yaris sedan 2008
my problem has not solution
my problem is input speed sensor turbine dont send signal to the computer and the result is the fourth speed not found .... can any help me
basharalezze is offline   Reply With Quote
Old 02-16-2015, 09:01 AM   #2
Have you replaced the turbine sensor? If you did and you are still seeing the same error code, then the transmission is slipping.
Old 02-16-2015, 11:51 AM   #3
basharalezze
thank you . but do you think the reason is computer of car
Old 02-16-2015, 12:10 PM   #4
The computer could be the issue, but the sensor or the internals of the transmission are far more likely to be the problem.
Help: dealer might not be able to fix window problem (2012 Yaris) matti Third Gen Yaris General Discussion 5 01-31-2013 11:37 PM
Car Race/IDLE/initial speed Problem mamun22s DIY / Maintenance / Service 0 08-28-2012 07:29 AM
Problem with electronic door lock new-yaris-owner In Car Entertainment + Electronics (audio / video / alarm) 7 08-05-2012 06:12 PM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 07:37 PM
Brake problem 1saneguy General Yaris / Vitz Discussion 15 11-24-2008 04:56 AM
