Old 11-16-2008, 09:00 PM   #1
1saneguy
Drives: 2007 Yaris Hatchback
Angry Brake problem
Hi everyone:
My Yaris is 2nd-hand, so not sure what happened in its previous lifetime.
I have a problem with the rear-passenger brake: occasionally, it catches stronger than the rest, to the point that the wheel locks. It happens when I first pull out of the garage in the morning or when I drive through rain and/or snow. Caveat: it is not consistent - it does not happen every morning, it does not happen each time I drive through cold & wet weather.
This is what I know & tried so far:
- I don't use the hand brake at all
- my mechanic replaced the brake cylinder, which did not resolve the problem
- I experience the same behavior with a rented Corolla a while back.
Has anyone experienced anything similar? If so - what was the cause & the solution?
Your feedback will be highly appreciated.
Thanks for help.
1saneguy is offline   Reply With Quote
DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads ChinoCharles DIY / Maintenance / Service 40 10-13-2017 05:23 PM
Problem removing front brake rotor jkuchta DIY / Maintenance / Service 24 02-27-2016 09:41 PM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 07:16 PM
big brake kit turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-13-2007 01:44 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
