Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Do you have ABS?
ABS is more prone to locking up in slippery conditions
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
![]() Drives: 08 Yaris sdn Join Date: Oct 2008
Look to see if the little rubber cover for the brake adjuster slot is in place.
My guess is that your getting moisture between the brake shoe and drum and it's "rusting" together overnight causing your wheel to lock until you break the fused drum from the shoes. |
Drives: yw calls me douche and racist. Join Date: Aug 2007
Joey
| DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads | ChinoCharles | DIY / Maintenance / Service | 40 | 10-13-2017 05:23 PM |
| Problem removing front brake rotor | jkuchta | DIY / Maintenance / Service | 24 | 02-27-2016 09:41 PM |
| BIG(GER)TM BRAKE KIT | Vanderkitten | Performance Modifications | 23 | 01-04-2009 07:16 PM |
| big brake kit | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 04-13-2007 01:44 PM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 09:12 PM |
