Going Retro
Drives: '09 Tacoma | '90 Tercel Join Date: Aug 2010
Warning light removal/replacement
I'd just like to know what the process is for getting into the instrument panel and pulling out/changing the warning lights. I'll be getting a 2nd set of wheels soon and I don't need an inaccurate (and expensive) TPMS because I check my own damn pressures every time I go out for a drive, and would like to pull the warning light so it doesn't annoy me.
I was going to prop up a small Domo in front of my light..
I too would like to snuff out that light..
Check out my DIY on disabling the indicator. It's easier to do it at the TPWS module then to do it in the cluster.
http://www.yarisworld.com/forums/sho...light=tpws+diy
Going Retro
Well, not for nothing, but down the road I also plan on doing an a-pillar gauge and that'll probably set off an airbag light when the original is removed... so it's better to know now how to just remove the bulbs. :P
#5 | |
Here's a thread about how to change the color of the LEDs in the cluster that shows the details of removing and taking apart the cluster. All of the indicators are LEDs, so removing them means desoldering. http://www.yarisworld.com/forums/sho...r+color+solder
| SRS warning light - any guesses? | Goose | DIY / Maintenance / Service | 15 | 03-24-2014 01:57 AM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| How do you reset the TIRE PRESSURE WARNING LIGHT | penny09 | DIY / Maintenance / Service | 3 | 09-26-2010 02:53 AM |
| SRS warning light and dealership fun :) | wsladaritz | General Yaris / Vitz Discussion | 16 | 09-18-2010 04:37 PM |
| Washer fluid warning light "Backwards" | Snyprwlf47 | General Yaris / Vitz Discussion | 2 | 02-15-2010 08:47 PM |
