Old 09-25-2010, 03:35 PM   #1
penny09
penny09's Avatar
Drives: 2009 yaris
How do you reset the TIRE PRESSURE WARNING LIGHT
I have reinflated my tires on my 2009 toyota but the warning light is still on. The owners manual does not describe how to reset the light. How do you reset that light?
penny09 is offline   Reply With Quote
Old 09-25-2010, 03:44 PM   #2
detroiter
detroiter's Avatar
Best bet is to disconnect the battery for a few minutes and then reconnect, start the car on up. Problem should be solved :)
Old 09-25-2010, 04:30 PM   #3
Clintondmb
Drives: '08 3DrLB.
it should go off after being driven a few miles. Thank you all you lazy SUV owners who didn't inflate their tires properly and got yourselves killed. We all now suffer for your laziness and stupidity.
Clintondmb is offline   Reply With Quote
Old 09-26-2010, 02:53 AM   #4
guyver408
Drives: 2009 Yaris 5dr
light should go off after proper inflation & a few rotation of the tire. I had the light go on because one tire was 25 psi vs the rest at 35. After inflation to match the others, and driving for a few hundred feet, the light went off. Light reappeared a few day later & I found a screw in the tire which was causing a slow leak.
good luck.
guyver408 is offline   Reply With Quote
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
tire pressure light Lorenzo1950 DIY / Maintenance / Service 4 08-23-2010 10:20 PM
tire pressure light goes on and off, on and off janices_yaris DIY / Maintenance / Service 8 07-30-2010 03:58 AM
