Old 05-05-2011, 11:53 PM   #1
Dperry
Dperry's Avatar
Drives: 2007 black yaris hb
Front left clicking wen turning
when ever i turn like pulling out of a driveway or parkinglot my left front tire clicks. iv been told either wheel bearing or axle....need more input before i start buying parts.
Dperry is offline   Reply With Quote
Old 05-06-2011, 06:49 AM   #2
Vinceb
Drives: 2008 5 Speed Sedan
Usually when a wheel bearing is gone it makes noise all the time while driving. when driving around turns at speed (not just from a stop) it would be a dull almost rubbing sound. I would think it could be the axle or could be a bad ball joint that clunks around when making the tight turn.
Vinceb is offline   Reply With Quote
Old 05-06-2011, 07:02 AM   #3
sickpuppy1
Drives: 2010 Yaris Sedan
Typically a bearing growls and a CV joint(axle) clicks around corners. The balls inside a CV joint get dry if the boot is torn or out of grease for some reason. Or just worn out/broken. They click in and out of the socket making the noise you hear. You could have it checked by a suspension pro if you want to make sure first.
Old 05-06-2011, 12:35 PM   #4
Dperry
Dperry's Avatar
thanks ill have it checked out ill take a look at the cv boot and see if it ripped maybe then i can rule out a machanic
Old 05-06-2011, 02:37 PM   #5
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Usually if the boot is torn the bearings in the joint have been exposed to a lot of road crap and are probably damaged(Clicking noise) repair usualy involves taking the whole drive shaft out and replacing bearing and boot.
Old 05-06-2011, 06:18 PM   #6
auxmike
auxmike's Avatar
You can also replace the whole shaft with a rebuilt unit. I'm checking for bearing "howl" myself on my car. Mabye it was the road I was on, I'll have to keep listening for it.
I've been tempted to trade it in for a new Corolla while gas is still such a ripoff...
Those Corollas are pretty SWEET!
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
Volume fluxuations front to back and left to right? PeacePiper In Car Entertainment + Electronics (audio / video / alarm) 3 11-27-2009 02:24 AM
Front left headlight out Jem_hadar DIY / Maintenance / Service 50 08-02-2009 06:16 PM
