Old 07-10-2011, 08:20 PM   #1
gabriel2012
Drives: 2011 Base Sedan
AC makes a rattling noise when turned on.
Kinda wierd, I was driving around and my friend called me so I turned down the radio...once I finished talking I heard a rattling noise(quiet since the ac was set to 2)
I didn't think it was the ac, just something inside making noise against one of the plastic panels or something....until I turned the thing into 4....started rattling like crazy. then I stopped and popped the hood and noticed the noise was louder.
I can describe the noise as *clack clack clack clack clack* checked the fan to see if something got stuck in there but no luck.
http://db.tt/QIWZ2E2 Click to signup for dropbox, and get bonous space, I do too!
gabriel2012 is offline   Reply With Quote
Old 07-10-2011, 08:57 PM   #2
If you don't have a cabin air filter installed then it is probably something stuck in the fan. Pull the lower passenger glove box to take a look. If you flip the AC intake knob to full recirculate you will be able to look right into the fan.
Old 07-10-2011, 09:00 PM   #3
gabriel2012
I have a cabin air filter(replaced it a few months ago) its installed. do I try it anyways?
Old 07-10-2011, 09:44 PM   #4
gabriel2012
air filter had some dust but when I took it out there wasn't anything inside the white circular thing that spins when the ac is on.
Old 07-10-2011, 10:20 PM   #5
Did you run it with that open to see if the rattle is coming from in there?
Old 07-10-2011, 10:34 PM   #6
gabriel2012
yes I ran it, but the clicking noise can be heard louder when I pop the hood...I really hope its not the compressor my car only has 46k miles.... my highlander has 200k and I haven't had any problems with the AC :/
When I tested this out, the clicking was soft when the ac was off....getting louder and louder as I moved up to 4.
Old 07-12-2011, 06:11 PM   #7
gabriel2012
Got it checked out at 2 a/c shops today...both found the culprit to be the compressor going bad and the noise is coming from something lose inside of it.
the first shop quoted an aftermarket compressor(new) at $1,039 installed.
the second shop quoted Aprox. $550...the compressors is around $300(rebuilt) + trading in the bad one. the labor would be around $175 + tax which would bring it up by $550 total.
The dealer quoted $2,100 for the whole job....
I need to fix it...the heat wave in Puerto Rico isn't getting any cooler.
Old 07-12-2011, 06:55 PM   #8
jekqmb
Local Sh*t Disturber
Drives: 2009 Yaris LB
Ya the compressor took a shit, its the clutch bearing that probably went out....
Old 07-12-2011, 07:03 PM   #9
gabriel2012
:/ there goes my pay check... going to check out the warranty from the rebuilt one...
This sucks, I was going camping with the yaris so we could save gas on the 2hour trip...gotta get there on the old highlander now :/
Rattling noise FunkyCole DIY / Maintenance / Service 10 08-27-2015 07:28 PM
Yaris makes a grinding noise while turning jonathankoji DIY / Maintenance / Service 7 07-06-2011 08:01 AM
Rattling noise when stopped herkfsu DIY / Maintenance / Service 2 02-28-2011 02:32 PM
annoyin noise (ticking or rattling) on idle.. abdallah380 DIY / Maintenance / Service 2 04-18-2009 06:40 PM
Rattling Noise with A/C Fan? Sabretooth DIY / Maintenance / Service 16 05-15-2007 04:27 AM
