Old 06-17-2009, 09:12 AM   #1
FunkyCole
FunkyCole's Avatar
Drives: 07 Toyota Yaris
Rattling noise
Ok so I hope some one has had this happen and knows how to make it stop. When I'm in drive or reverse and I am at a stop light there is an annoying rattling sound, it sounds like its coming from the engine bay, I just cant find it. The car is a 2007 Sedan with 40,000 miles on it. If anyone has any ideas of what this noise could be, please let me know.
Thanks,
Jimmy
FunkyCole is offline   Reply With Quote
Old 06-17-2009, 09:22 AM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
There are too many possible rattles under the hood to diagnose from afar. You're going to have to get under the hood and listen to narrow it down.
Old 06-25-2009, 10:36 AM   #3
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
I had a similar problem they tightened/adjusted a shift linkage type cable I believe it was called, maybe someone can advised there was a TSB on it per the Toyota dealership. I hope this helps or gets you in the right direction. I wish I could tell you more.
198K Miles
N9QGS is offline   Reply With Quote
Old 06-25-2009, 03:40 PM   #4
abdallah380
Fly Emirates :)
abdallah380's Avatar
Drives: 2010 Yaris Sedan
hey, hope this helps...
http://www.yarisworld.com/forums/sho...oying+rattling
abdallah380 is offline   Reply With Quote
Old 06-25-2009, 05:48 PM   #5
kenora
Drives: 2009 Yaris LE 5 dr
I had the same thing (or similar)...it was a rock under the heat shield of the exhaust pipe.
kenora is offline   Reply With Quote
Old 06-26-2009, 04:32 AM   #6
auto pal
Drives: 2008 toyota vios 1.5G A/T
rattling noise
in my yaris sedan, i narrowed it down to the air filter box. however,
i haven't been able to fix it yet because i haven't had time to tinker
with it and find out which screw or bolt to tighten.
auto pal is offline   Reply With Quote
Old 06-27-2009, 08:23 PM   #7
N9QGS
N9QGS's Avatar
I wanted to add one more item to check that was a rattle in reverse and idle... see if the air intake duct is vibrating against the hood release cable. I had noticed that my air box vibrates at idle and the air intake duck (hard plastic) would vibrate cause its mounted together and it was hitting and also cutting the shield off the hood release cable. But this made a lot of rattle.
198K Miles
Old 06-28-2009, 05:00 AM   #8
abdallah380
Fly Emirates :)
that was the exact same problem with my car... so all i did was taped the cable to the body of the car so there is a bit of enough gap between the cable and the air intake duct.
Old 08-27-2015, 06:26 AM   #9
John Lenin
Drives: 2009 Toyota Yaris 3-Dr HB Auto
I've had two similar rattles that I've easily fixed using ordinary zip ties ...
The first was a lower pitched rattle that did not sound like metal-on-metal, but rather more like loose plastic ... occurred when car was idling at a stop light with the trans in "Drive" (D) ... figured it out as being the snorkel on the Air Box (front right under the hood facing the car) ... it wasn't fitting snugly to the Air Box and was vibrating causing the noise ... wrapped a long zip tie around it and strapped it tightly to the nearest hood stop ... and stopped the annoying rattle!
Second was the infamous vibrating transmission control cable covered in a TSB ... again, using a zip tie I secured the cable to the bracket just above it ... accessed it from under the hood (thankfully I have small hands!).
Both fixes took about 5 mins each and cost practically nothing (zip ties are dirt cheap now-a-days!)
John Lenin is offline   Reply With Quote
Old 08-27-2015, 09:10 AM   #10
bronsin
bronsin's Avatar
My 09 has had the cable rattle since Day One.
But if you think Im spending the money on a zip tie to fix it....HA....HA!
Old 08-27-2015, 06:28 PM   #11
nookandcrannycar
You might just be more frugal than I am!
Rattling Noise Trilixia DIY / Maintenance / Service 19 09-27-2009 08:59 PM
Noise from the drums.... Lafiro General Yaris / Vitz Discussion 18 05-22-2009 09:49 AM
annoyin noise (ticking or rattling) on idle.. abdallah380 DIY / Maintenance / Service 2 04-18-2009 05:40 PM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 04:21 PM
Rattling Noise with A/C Fan? Sabretooth DIY / Maintenance / Service 16 05-15-2007 03:27 AM
