Idle Fluctuation due to aftermarket intake?
Installed the Weapon Research intake just last month and now I have this intermittent idle fluctuation. It doesn't happen all the time but the symptoms are always the same. After the car is warm, rpms will rise to 900-1000 rpms and then drop to around 700-650 rpms. This will continue to happen as long as the car sits at idle. I usually notice it when I pull up to a stop light. As I said, this doesn't happen all the time. Was wondering if anybody else has this issue with any of the other intakes or if this is a common problem? From my experience with motorcycle carburation, this symptom usually means that the idle jet is too big. Since this car is injected, I have no idea why it might be doing this. Seems like it happens more when it's humid outside but that could be my imagination. I also have a custom cat-back magnaflow exhaust. This could also be part of the issue.
#2 | |
![]() ![]() ![]() Drives: 2011 Rogue Join Date: Jan 2006
I don't have a tachometer, so I don't know what the RPMs look like... I also have no Engine Mods... Just a Short Shifter Kit... But sometimes when my Yaris is fully warmed and sitting Idle at a red light... The engine starts shaking the car slightly... And it definitely has a rhythm to it! I was starting to think this was a normal thing in small cars, but this post has just made me nervous!
The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
my yaris did it when it was stock, still does it after exhaust on it. exhaust didnt change it. something about the engines idle control...i noticed it does it at any time when at a stop when the transmission is in neutral and it is iddling...it normally sits at 800rpm...then it drops to 500rpm and the engine shudders and then it spikes to 1000rpm.
im sure its either normal or a recall that toyota will send out at a later date,lol.
that has happened to me a couple of times, and my Yaris is bone stock.
Ok. SO it's not something with the Weapon intake. That's good. I thought I might have an intake leak or something. It does make me wonder why this is happening though considering it happens to cars that are stock and that have mufflers and intakes. Maybe poor engine mapping or an overly sensative ECU. Electric power steering maybe?
I'd like to get a little further into this. Anybody else have this problem or who might have a possible explanation? Chris? Chino? eTima?
I don't really remember how it was before changing the intake and exhaust, but I think it is normal, especially as we have an electronic throttle, the ECU always does some tricks with it.
Plus, when idling, the ECU also alternates between a rich and a lean fuel mixture, this is to keep the catalyser working at peak efficiency, so it may also have an effect on the idling speed.
#8 | |
Turbo Yaris
Drives: 07 PW Yaris Join Date: Dec 2006
It happens bone stock to all of us. Notquite sure why. It is in the stock programming.
Well I usually have the air conditioning running, so that itself will cause the idle to fluctuate, but when it's off, yes, it will go up and down over time. I really don't think it's anything to worry about.
Next time I drive I'll keep the AC off and double check to see if there is a relation between the AF ratio meter and the RPMs.
After hearing that this is a common problem, I don't think it's anything to worry about in terms of potential mechanical issues. What bothers me is that this is a new car and as such there should be no idle fluctuation once the car is warm. Thanks for the input.
Sure, but as the saying goes, it's a feature, not a bug
It sure is! It's to let you know the car is till on :P. I remember the first time I gave a some friends a ride they were quite sure the car was off! :P
My car does the same thing too. Next time I go to the dealership for the oil change (bought the package) I'll ask the tech about it (if I remember). |
#14 |
Mine does that as well, idles around 800-1000 then drops and shudders slightly. I cant imagine that is a built in feature for anything... I had the same problem with my previous car.
Funny thing is the Yaris developed this idle fluctuation about 10000km not right off the lot. Does the yaris use the throttle body for idle air control or is it a seperate valve as on other makes/models?
http://www.cardomain.com/ride/2336679 |
#15 | |
#16 |
![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2006
yup...I noticed the same looping a while back and thought it was kinda sweet! Usually you only get that on tuned cars...the aspirations of a bone stock Yaris...
#17 |
Drives: Toyota Yaris 2007 Join Date: Dec 2006
its the recirc valve ... uses exhaust air to heat up the air going to the intake
#18 | |
![]() ![]() ![]() Drives: 07 yaris s sedan Join Date: May 2006
ok first off the yaris doesnt have a recirc valve, that is a part from the dark days of emissions control. the problem the original poster is having is the a/c compressor kicking on and off, it seems like the computer is over/under compensating for the load change. i've noticed this on mine the only way to fix this will be a reflash of the ecu to smooth the change out. toyota has no released this as yet and i highly doubt they will. it may be annoying but it causes no ill effect to the car as long as it's not stalling out or anything like that. |
| WR Secret Weapon Intake Dyno Tested.. | WRLEO | Performance Modifications | 70 | 05-17-2007 03:00 PM |
