Old 12-18-2006, 04:21 PM   #1
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
Mine does that as well, idles around 800-1000 then drops and shudders slightly. I cant imagine that is a built in feature for anything... I had the same problem with my previous car.
Funny thing is the Yaris developed this idle fluctuation about 10000km not right off the lot. Does the yaris use the throttle body for idle air control or is it a seperate valve as on other makes/models?
mikeukrainetz is offline   Reply With Quote
Old 12-19-2006, 01:18 AM   #2
As far as I remember from the technical manuals the idle is controlled by the electronic throttle.
Old 12-20-2006, 07:35 PM   #3
H2XcapePod
Drives: 07 Yaris LB
yup...I noticed the same looping a while back and thought it was kinda sweet! Usually you only get that on tuned cars...the aspirations of a bone stock Yaris...
H2XcapePod is offline   Reply With Quote
Old 12-22-2006, 04:30 AM   #4
muncher
Drives: Toyota Yaris 2007
its the recirc valve ... uses exhaust air to heat up the air going to the intake
muncher is offline   Reply With Quote
Old 12-22-2006, 04:41 AM   #5
El Jefe
Drives: 07 yaris s sedan
ok lemme straighten some things out in the thread, i see alot of mis-informantion here
ok first off the yaris doesnt have a recirc valve, that is a part from the dark days of emissions control.
the problem the original poster is having is the a/c compressor kicking on and off, it seems like the computer is over/under compensating for the load change. i've noticed this on mine
the only way to fix this will be a reflash of the ecu to smooth the change out. toyota has no released this as yet and i highly doubt they will. it may be annoying but it causes no ill effect to the car as long as it's not stalling out or anything like that.
El Jefe is offline   Reply With Quote
Old 12-22-2006, 12:31 PM   #6
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
But I live in San Francisco, I've never even used the a/c. I'm just satisfied knowing that this is a problem with more than just my car. I do agree with you though, I doubt Toyota will ever do a recall to fix the problem.
Galavoxx is offline   Reply With Quote
Old 12-22-2006, 05:59 PM   #7
El Jefe
how often do you have your car in either of the defrost settings? that also turns the a/c compressor on even tho the little light does not come on.
try it out and let me know, test it with the a/c on or in defrost mode, and then with everything totally off.
WR Secret Weapon Intake Dyno Tested.. WRLEO Performance Modifications 70 05-17-2007 04:00 PM
