Old 12-22-2006, 03:41 AM   #18
El Jefe
Drives: 07 yaris s sedan
Originally Posted by muncher View Post
its the recirc valve ... uses exhaust air to heat up the air going to the intake
ok lemme straighten some things out in the thread, i see alot of mis-informantion here
ok first off the yaris doesnt have a recirc valve, that is a part from the dark days of emissions control.
the problem the original poster is having is the a/c compressor kicking on and off, it seems like the computer is over/under compensating for the load change. i've noticed this on mine
the only way to fix this will be a reflash of the ecu to smooth the change out. toyota has no released this as yet and i highly doubt they will. it may be annoying but it causes no ill effect to the car as long as it's not stalling out or anything like that.
El Jefe is offline   Reply With Quote
WR Secret Weapon Intake Dyno Tested.. WRLEO Performance Modifications 70 05-17-2007 03:00 PM
