Old 07-06-2021, 03:16 PM   #1
Jwahlberg
Drives: 2010 Toyota Yaris Hatchback
Access to body panel behind passeger seat
Hi,
Someone hit our 2010 Yaris Hatchback a few weeks ago while it was parked at a store. The point of impact was the body section behind the passenger door. There are no scratches or breaks in the metal.
Using misc strong suction cups, I was able to undo 60-70% of the major dents but a significant portion still remains.
Unless there's a miracle process available to deal with this type of damage, I will need access to the "body" from inside the car. My current thought is to use a rubber mallet and carefully attempt to restore the damaged areas. But, it's not clear to me how to properly access the affected area from inside the vehicle. For example: Can I access the said area without having to remove the back seat? If yes, what is the proper order and process to open/remove the surrounding panels?
I've looked on this forum along with other sites, YouTube, etc, but have not been able to find the info I'm looking for, hence posting.
Thanks you VERY much in advance for any advice!
-- J
Jwahlberg is offline   Reply With Quote
Old 07-09-2021, 10:21 AM   #2
Neinris
Drives: 08 Yaris 3 Door Hatchback
Do you have any pictures? I have the 2nd gen door hatchback, for me there are plastic panels that I can remove to get to the skin of the car.
Have you tried the hot glue stick trick? Remember, you'd want to pull out the shallow parts of the dent first, the deep end last.
Good luck!
Neinris is offline   Reply With Quote
Old 07-12-2021, 06:23 AM   #3
iirc, there are two sheet panels back there, so you won't be able to access the dent/damage from the inside of the car.
DIY: Replacing 2-Door Liftback Door Panel Fabric redyaris DIY / Maintenance / Service 25 06-25-2024 01:24 AM
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 09:15 PM
Back Seat Removal... Idjiit DIY / Maintenance / Service 87 02-08-2015 12:07 PM
F.S. MOMO Acropolis Evo Carbon Kevlar Competition Seat with 4 piont Harness Ric n Sov's Vitz RS Items for Sale by private party 2 10-19-2008 01:34 AM
Anyone know how the passenger seat detection system works? rage2 DIY / Maintenance / Service 5 05-12-2007 07:22 PM
