Old 05-27-2007, 07:21 PM   #1
redyaris
Shiny Chromey Coolness
redyaris's Avatar
Arrow DIY: Replacing 2-Door Liftback Door Panel Fabric
Heres one for all Yaris polka-dot haters. This DIY is for recovering the interior door panels for your liftback (I would assume its the same process for the sedan but I don't know for sure). This one will take about 3 hours start to finish.
Supplies: Gloves and a can of headliner spray adhesive, and one yard of whatever fabric you wish to recover the door accent panels in (make sure the fabric is thick enough that the glue will not soak through). I chose 3mm thick neoprene for my fabric replacement.
1. Remove both your door panels. Refer to the DIY on Yarisworld for this http://www.yarisworld.com/forums/sho...+panel+removal . Its very easy!!!
2. Remove the plastic window trim piece on the interior of the door panel near the top. Its held on with a few small prongs you can carefully bend to remove this trim piece.
3. Now begin stripping the polka dot fabric off the door panel. Be careful not to rip it because you'll need the entire piece to use as a pattern for your new fabric. Needle nose pliers will help you grab tucked-in pieces where your fingers wont reach. Dont worry about the remaining glue on the door panel unless you want to add another hour to this project removing it.
4. Lay the removed polka dot fabric on your new replacement fabric and cut closely (but not too close) to it to make your new fabric pattern. Dont worry...it doesnt have to be exact! Make note of the tabs on the old fabric and cut these out also (the tabs tuck under the door panel trim to assist in holding the fabric in place. Keep your old polka dot fabric patterns...you never know when you might need them again! NOT.
5. You will have a problem with the trim nearest the rear part of the door. I had to break it loose with a screwdriver to remove this area of fabric. Now I have to drill 3 trim screws (each door) back into it to hold it. No problem. I dont know how you cover this area without breaking this piece free.
6. Spray the exposed fabric area of the door panel with the headliner adhesive. I coated it well but not soaking wet. Allow 5 minutes minumum for sprayed adhesive to become tacky to touch. The adhesive does not bond instantly so you have a little working time with it.
7. Lay your new fabric pattern on the wet adhesive door panel. You get about 2 minutes working time. Press the fabric down and smooth it out on the panel. Make sure you smooth the area immediately by the door handle opening (there is a noticeable ridge there the fabric needs to contour to).
***NOTE: If you are using neoprene like I did there is no need to stretch it, let it lay normally over the door panel. Stretching it will cause stress on the glued area.***
8. Spray interior of door panel and tuck over top of door and side of door, cutting to fit. Tuck corners to hide where trim will cover up. Use adhesive liberally on this step.
9. From the inside of the door panel poke a hole in the door handle cutout and cut the door handle opening leaving enough overlap for the door handle to cover from the inside of the door. DO NOT cut the hole too close to the panel cutout!
10. Test fit door handle trim to ensure fabric coverage all around. Let dry for at least one hour before putting door panels back in car.
11. Clean up any visible adhesive overspray from interior door panel with glue removal product such as 'Goof Off'.
12. Enjoy your non-polka dotted doors!!!! Now cover your seats to match!
Old 05-27-2007, 07:24 PM   #2
redyaris
redyaris's Avatar
Part 2 Pics
Part 2 Pics
Old 05-27-2007, 07:33 PM   #3
OxyG3nE
Drives: Toyota Yaris 2007
Send a message via AIM to OxyG3nE Send a message via MSN to OxyG3nE
look really nice ..!! you make me want to do this haha
OxyG3nE is offline   Reply With Quote
Old 05-27-2007, 07:37 PM   #4
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Thumbs up
Nice, I gotta get some black pleather. I'm going vegan leatherette interior.
SPONSORED BY
Old 05-27-2007, 07:45 PM   #5
kurokoma-kun
Drives: 2007 Yaris HB
Redyaris, that is beautiful! The neoprene looks awesome even better than my suede I think (which I have still not finished )
Great DIY too! I'm sure it will be appreciated...
Old 05-27-2007, 07:49 PM   #6
uncleyaris
great job, congrats! looks great.
Old 05-27-2007, 07:56 PM   #7
redyaris
redyaris's Avatar
No bovines were killed for this DIY!
Old 05-27-2007, 08:01 PM   #8
brickhardmeat
Lonesome Cowboy
ha, maybe fish scale interior
neoprone looks nice I hope it holds up in the heat and sun well
did you find the stretchy quality of this fabric made the install easier?
SPONSORED BY
Old 05-27-2007, 08:05 PM   #9
redyaris
redyaris's Avatar
Now I have to get the windows tinted!!!!
Btw, I have enough neoprene left over to cut pads for the front storage bins and wrap my factory armrest too.
Hmmm, never noticed how much the polka dots looks like a dress my wife owns.
Old 05-27-2007, 08:18 PM   #10
redyaris
redyaris's Avatar
The stretchiness did make it easier but as I noted if you use neoprene DO NOT stretch it. Let it lay normally over the door panel. Stretching it will cause stress on the glue causing the neoprene not to contour properly....and the fabric will become thinner causing rips and holes.
Old 05-27-2007, 08:20 PM   #11
ChinoCharles
Drives: LB
Hey redyaris... hats off man! What a difference! This is definitely one of my favorite DIY's to date, and its obvious you took great care doing a perfect job the first time! Congratulations and thanks!
Old 05-27-2007, 10:12 PM   #12
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Hey redyaris! Looks really good... I'm very impressed with the finished product! The TRD badges are a nice touch too.
2006 Red Blitzed RS 5-door
Old 05-27-2007, 10:30 PM   #13
death is my gift
wacky broadway nightmare
death is my gift's Avatar
Drives: Willow is a '07 Red Yaris LB
Send a message via AIM to death is my gift Send a message via MSN to death is my gift Send a message via Yahoo to death is my gift
i'm so jealous of YOUR red yari. so so nice dude.
"it's always complicated and at some point someone has to draw the line and that is always going to be me. you get down on me for cutting myself off but in the end the slayer is always cut off" Buffy
death is my gift is offline   Reply With Quote
Old 05-27-2007, 10:59 PM   #14
Black Yaris
der Zeck
Black Yaris's Avatar
Looks killer, I have been pondering if and when I was going to do this, I was just wondering what I would be getting into, and thanks to you nicely written DIY my problem is solved... they realy turned out nice, when I herd you say neoprene, I thought it was going to look god awful, but is is realy sharp.... any pix of the back?
Old 05-28-2007, 09:41 AM   #15
redyaris
redyaris's Avatar
Thanks people!!!
Old 05-28-2007, 08:44 PM   #16
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
great diy! how about the headliner and maybe even the dash board?
Old 05-29-2007, 10:21 AM   #17
redyaris
redyaris's Avatar
The factory headliner is ok for me...cover the dash in fabric???? EEK.
Old 03-18-2009, 12:41 AM   #18
manlyyaris
manlyyaris's Avatar
Drives: USDM white liftback
Thanks alot! this is amazing!
manlyyaris is offline   Reply With Quote
