やりすぎだ~
Q: when shifting into neutral... clutch?
Throwing out this question to all of you. Let's say I'm in a gear (3rd,4th,5th, etc.) and I decide to shift into neutral to save some gas and coast. As a habit, I always press the clutch before I shift into neutral. Do I need to press in the clutch or can I just shift it out of the gear straight into neutral?
ヴィッツ ドライバー
Drives: 2006 3d 1.0 Linea Sol Join Date: Aug 2007
1) Yes, you should depress the clutch.
2) Coasting while in gear (not in neutral) will save you more gas. Check out this thread: http://www.yarisworld.com/forums/showthread.php?t=4248 |
Yes and no. Because there are synchros in the transmission you do not need the clutch to shift gears, much less shift into neutral.
But to do that you have to match the speed of the engine to the transmission, for the particular speed the vehicle is traveling. Once you get the hang of it you can do it. But that might take some time and do some dammage.
![]() ![]() ![]() Drives: 2010 NCP91 5spd Join Date: Nov 2009
To add into it;this is something many truck drivers do (much different when you have 18 speeds as opposed to 5). . . what you NEED to do to do this properly is to take the load off the engine/flywheel/transmission. The optimal point to shift OUT of gear is some point between having your foot on the gas and releasing the pedal.
Now you can also do the reverse; shift INTO gear without the clutch too, but you have to either wait for the engine speed to drop (upshift) or rev-match to the appropriate RPM (downshift). Needless to say, there is no point in doing this. If you are too lazy to press the clutch pedal, you should have bought an automatic. And even if you perfect the practice, the margin for error is so small that one day you will eventually make a mistake and grind the gears; hardly worth it considering the Yaris' clutch (pedal effort) weighs about the same as a goldfish penis. And, if I misunderstood the OP's post and am talking about something completely different, my apologies. *PS if you choose to do this anyway, there's is another note. You should never EVER have to force the shifter in/out of gear. If done correctly, the shift will be effortless (no different than normal shifting), but nonetheless shifts need to be done precisely and quickly (as the window to shift is very small). If you have to push the gear shift a bit harder than usual, it means you are exerting extra pressure on the gears/synchros which is bad. And obviously if you grind the gears, that means you're doing it wrong!
The best modification you can make is between the steering wheel and driver's seat. |
#5 | |
![]() ![]() ![]() ![]() Drives: 2017 Yaris IA, Pulse Red, Auto Join Date: Jun 2010
I depress the clutch. I also (at stoplights when I have the red light) shift into neutral rather than holding the clutch in for the duration of the red light. I read awhile back in CarTalk that this makes the clutch last longer. I've never had a clutch go bad and I've had plenty of manual's.
#7 | |
"But Mama, that's where the fun is"
There's no fun in breaking your transmission; especially if it's to do something that adds zero performance or efficiency benefits. Some people would call taking a sledge-hammer to their engine fun. I'm perfectly fine calling them morons. To each their own. Have fun... Just don't complain that your car is a lemon if you have transmission problems 1-2 years down the line.
Leaving your car in gear with the clutch in at a light WILL be detrimental to the clutch.
Shifting into neutral (or shifting gears) without using the clutch wont hurt a thing if done right. ![]() Its also a nice skill to have because if your hydraulic clutch leaks leaving the clutch inoperative, you can still drive. So get a manual transmission with your next company car and have at it!
It IS a nice skill to have, and it's not a bad idea to learn how to do it. It's a terrible idea to make it a habit to do it all the time for no reason (the OP's point insinuates that, which is why I am making such strong statements). I badly hurt my left leg in a motorcycle accident in the USA, and the skill proved invaluable.
Sorry to hear about the accident. I ride also.
#13 | |
ヴィッツ ドライバー
Speaking of being able to do stuff and doing it on a regular basis just for the heck of it... there's a Bear Grylls reference in there somewhere.
Thanks! And sorry for the snappy replies... Turns out we basically agree, hahaha.
![]() ![]() ![]() Drives: 2008 5 sp. LB Join Date: Oct 2010
I routinely shift the Yaris without the clutch, done right the tranny doesn't know the difference. Not a recommendation for you to do so, I do it from habit as I use the Yaris to get back and forth from the crane yard. The truck the crane is mounted on weighs 40K, and standard procedure is to shift it clutch less, and you just get in the habit.
Unload the flywheel like others said, first. BTW the truck tranny is no stronger then the Yaris tranny, all rigs have trannys APPROPIATE to their payload, I would no sooner want to grind gears in the crane then I would in the Yaris, abusing any of them will cause harm eventually, smooth clutchless shifting in the Yaris, done right, is not hurting anything. I put 245K on a Toyota pickup, on the original clutch, same deal. No real advantage for most either, other then I suppose a little less wear on the clutch and throw out bearing. |
#17 | ||
Only Happy When it Rains
No idea how anyone got the idea of clutchless shifting out of the ops post. It is something that should never be done outside of a semi.
Colin Chapman disciple |
^If u refer to hypermiling techniques, then I have no idea. But in most standard situations, it shouldn't make any difference. The Yaris has DFCO (deceleration fuel cut off), which means no fuel is being used while coasting in gear. Unless you are trying to coast for extremely long stretches (1/4 mi up), I can't see it making a huge difference. But I'm admittedly not a hyper-miler.
| HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. | trini_per4mance | DIY / Maintenance / Service | 42 | 03-27-2017 03:59 AM |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 05:20 PM |
| Shifting without the clutch | mark293 | General Yaris / Vitz Discussion | 91 | 07-12-2010 08:56 PM |
| Shifting into neutral | otterhere | Fuel Economy Forum | 24 | 01-17-2009 02:46 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
